Coilovers ... whats ones go the lowest?
tomb
NULL
As title says ..
Any pictures to back up whats been said will be an added bonus.
I have an avant but on any platform will do.
Thom.
How low do you want. Lowest you're going to go is not enough clearance for speed bumps.
Check out AP's range. I heard FK's are good for stance
If you want to go as low as possible try air suspension.
You can usually get coilovers a little lower by removing the helper springs.
Im going to be getting coilovers myself soon will be going for either Weitec or KW (Wietecs are made by KW so great quality)
I have heard that the shock absorbers in FK's are a common failure.
Air ride is out of the question as the cheapest kit i can make up will be around the £1700 mark.
Im looking to spend about £500 give or take a bit.
Just looking for maximum lows with relative comfort.
Damien do the FK coilovers come with any warranty on them?
Thanks Tom
I've got AP-X? coils (adjustable rebound) and they dont go very low on the rear! Ive got them fullf wound down but would like another 20mm or so!
Ryan
I've got FK's on my Avant and they sit pretty low, low enough that I have to raise them this weekend. The arch is currently sat about 35mm above the actual rim of my tucked 18's. For cheap coilies I'm pretty happy with how they ride as well.
Nice has anyone managed staticly tuck and wheel yet, not just tyre?
How low to the weitecs run?
N8; What Fks did you go for how to they sit?
Tom
Any FK's will go low as you can remove the helper spring. Not many other brands run a helper to remove!
