Chris NottVolks Autos
Results 1 to 26 of 26
Like Tree1Likes
  • 1 Post By Rudedaubin
Thread: Cabriolet headlight removal
    Oct 2012
    Stanley, County Durham
    148
    Hi all,
    was hoping someone could confirm that there is only 1 back screw to loosen per headlight when removing them from a cabriolet. I've read various guides and watched a vid on YouTube that all say to remove 2 Torx head screws on top and 2 Torx head screws to loosen per headlight, but when I've looked and removed my air box feed, I can see only one back screw to loosen. I then saw a very brief comment on another forum saying there is only one screw to loosen when doing the job on a cabriolet ( which seems to back up what I've seen!). Has anyone done this, and can you confirm?
    i need the answer specifically for a cabriolet please
    thanks,
    Paul
    VagCabby's Avatar
    Apr 2012
    Redhill
    209
    I can't remember exactly but it's deffo either two or three, there down the back of the headlight, possible one on the crossmember as well. Been a while since I did it but I managed it easily, only took max 10 mins per side, unbolt then they slide out without having to remove the bumper.
    Audi A4 Cabriolet 2.5TDI 163 Sport
    Full Interior Lighting Pack - Puddle Lights, Footwell Lights, Door Markers, Handle Ambient Lights, Air Vent Illumination, Armrest Illumination, Roof Ambient Lights. Auto Dim Rear View Mirror, Cruise Control, Full DIS, Genuine 6 Disc CD Changer in Glovebox, RNSE, Remote Windows, Parrot Bluetooth, Storage Pack, Full Leather, Heated Mirrors.
    Feb 2011
    Worcester, Worcestershire, United Kingdom
    44
    2 on the top to take out 1 at the bottom to loosen off then slide n wiggle out it pops don't forget the multiplug !
    Jan 2011
    661
    Put some low tack tape or plastic film on top of the bumper to prevent scratches too.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    Oct 2012
    148
    Thanks guys, that really helps! I was stumped, as every guide mentioned 2 screws on top to remove, 2 at the back to loosen off, but it seems that's only saloons/avants!
    j88ner - what do you mean by multiplug (sorry if I'm being thick!)
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,698
    It's the wiring plug.
    Jan 2011
    661
    Quote Originally Posted by pbarlow0032 View Post
    clips damage easily on the electrical connector, the trick is to push it in before you release it Replacing damaged headlight connector body - guide
    Oct 2012
    148
    Hi all, finally got round to looking at this today (needed a T30 Torx!). Managed to get the light unit out ok, but can't work out how to remove the multiplug, and having seen the link to how many broken ones there are, erred on the side of caution. Can anyone help a numpty with how to do it please? Not sure what needs to push in or pul?
    also, I can get the flap off the back and it seems easy to replace the main beam bulb, but how do you get at the side light and dipped bulb? Are there further screws to remove once inside the light unit?
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    65
    The sidelight is on a white plastic slider beneath the centre projector,you pull it back and the lamp is on the end of it. I think my dipped beam lamp (hid) needed to have a plastic ring unscrewed to get the lamp out.
    2004 A4 Sport Cabriolet 3.0
    Jan 2011
    661
    perhaps reading this and my last post will give you a help - Broken Tabs. How do I remove headlight harness plug?
    Oct 2012
    148
    So I think I'm pushing it in, then using a flat head screwdriver in the tab thing to lever it out?
    Am i right in saying that I have to remove the main beam bulb to get at the others? Are there any detailed guides on how to replace each bulb?
    Oct 2012
    148
    Well, the saga continues... I've had another fiddle at lunchtime, worked out how to remove the wiring plug.
    Can anyone give me a link to, or information on, how the different bulbs are accessed? When I had a look yesterday, main beam seems obvious, but the bulbs for sidelight and dipped don't seem obvious? Am I removing screws, or just unscrewing bulbs etc?
    Any help appreciated,
    Paul
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    65
    You slide the white plastic bit out of the back of the headlight unit to replace the sidelight. The dipped beam is removed on mine in the photo but you can see where it sits. You need a small torx bit to remove the three screws holding it in.
    Just had my headlights out looking for a solution to my poor xenon performance, quite obvious now but not sure how I'm going to repair them.
    JasonS's Avatar
    Feb 2012
    North Herts
    86
    Quote Originally Posted by Rudedaubin View Post
    what will you need to repair?
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    65
    Look at the area above the bulb holder, its burnt out , all of the reflective surface inside is black/ burnt and there's a big crack on it.
    JasonS likes this.
    JasonS's Avatar
    Feb 2012
    North Herts
    86
    Ahhh, yes. it's obvious now.
    That's not going to be helping your xenon light output.
    Previous Audis:
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Oct 2012
    148
    Doing my head in now, might just take it to Halfords! Got light unit off, managed to change main beam and sidelight, but can't seem to get dipped out? Rudedaubin, mine looks different to yours, I can see 2 T20 Torx screws which i've removed, but there seems to be a white plastic ball clip arrangement round the back side which I can't seem to shift? The dipped bulb unit looks like it might just twist out, but when I tried there was no real give so I didn't want to snap anything off! Any ideas? Picture below shows the block with 2 torx screws (one of which is removed) and although the other crew was loose, I couldn't shift the block. The dipped bulb is the one to the right of the photo with a blue plug in it.
    Also, replaced the side light with a LED and it just doesn't light up, but also doesn't throw up any warnings on the DIS - is it likely to be a one-off dud? I never had chance to try the other LED sidelight in it to see if it was just a dud as I ran out of time.
    Miffed to say the least. On the plus side, I'm a wiz at getting the light unit in and out now!
    Related question - has anyone used toothpaste to refresh their lights? Saw it on youtube and wondered if it worked? If it does, do you need to put anything else on the lights afterwards?
    JasonS's Avatar
    Feb 2012
    North Herts
    86
    You have halogen lights, not Xenon, so are different.
    Workshop manual says to turn dipped beam bulb anti-clockwise and pull out.
    Toothpaste works as a mild abrasive, just buff off.
    Previous Audis:
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Oct 2012
    148
    Thanks Jason, I really appreciate the help. Can you just confirm please, I rotate the full silver circle anti clockwise, or just rotate the blue plug which is in the middle of the circle? Should I be able to do it without removing the central square block with the Torx screws in it?
    Oct 2012
    148
    Does anyone know if its the full silver circle I turn, or just the blue plug?
    also, does anyone know on the led sidelight bulbs, is there a right way and a wrong way to fit them? They slot in with a flat connector, is there a positive and negative, or should they work either way?
    Oct 2012
    148
    Well I've finally worked out how to get the dipped bulb out, which contrary to everything on here is not a H7 bulb, it's a H9! Ring don't seem to do a 120% H9 bulb, so can any cabriolet owners who've changed all their bulbs recommend a crisp white H9 bulb please? I'm guessing the cabriolet is different to saloon/avant?
    Mar 2008
    Dorset
    13,698
    They must be, saloons and avants are definitely H7.
    Oct 2012
    148
    Well, finally managed to fit all 3 bulbs to driver's side (most fiddly because of the air intake), just need to fit the final bulb to passenger side today (dipped H9 bulb). Will try and take some photos later. Most impressed with the sidelight bulbs, look fab :-)
    Could do to sort out rear number plate LEDs now. Best to speak to t8ups?
    Mar 2008
    Dorset
    13,698
    Why the post dislike? The information I gave you is correct.
    I have bulbs from Trups in my rear plate lights, they've been in a year or so and have had no issue's, good price too.
    Oct 2012
    148
    Hi quattrojames, definitely wasn't an intentional post dislike, sorry if it offended. You've been really helpful, thank you. I'm posting from an iPhone with a broken screen so I could have hit anything! Can't fault anyone on this forum, everyone on here genuinely seems to want to help.
    i hope my trials and tribulations will help someone else if they come to change their cabriolet headlights. I'll try and put up some pictures tomorrow when I'm back in work showing a halfway shot and then a final finished photo.
    quattrojames, I meant to ask, are your rear number plate bulbs Led ones or just clearer halogen bulbs?
    thanks again for your help
    Mar 2008
    Dorset
    13,698
    BlackBerry trackpad ftw
    Mine are and LED upgrade, the only pics I have are of the previous bulbs, not the one's Trups supplies unfortunately, although they look the same.
  1. Headlight Removal
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2007, 20:33
  2. Headlight removal!
    By Bridger in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2006, 23:11
  3. Headlight removal
    By blue03 in forum TT/TT-S/TT-RS Forum
    Last Post: 11th November 2006, 08:12
  4. Headlight removal without bumper?
    By alfiejts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st October 2006, 20:22
  5. Headlight Removal
    By bioharry in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2006, 17:11
