AH FabricationsSky Insurance
Results 1 to 8 of 8
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    Cambelt change what mileage?
    What mlieage should it be changed on a A4 B6 1.8T 2001 plate?
    imported_ronny
    Re: Cambelt change what mileage?
    book says somthing stupid like 100k miles, but I would change at 60-80k miles
    Jun 2003
    World of my own
    9,813
    On the 4 cylinder diesel it is 60k, it is correct in the book but totally confusing as it includes all models and the 6 cylinder diesel and all the petrol models are all different intervals.
    Audination's Avatar
    Oct 2004
    Cumbria
    67
    Personally i would change it @ 60,000 ish just to be on the safe side especially if your keeping the car!
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    I'd better get it done soon, as it's on 66,000 :-(
    Should i also have the water pump done at the same time? as there is talk of changing it at the same time as the belt.
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    yes change the water pump aswell ,it should cost around 30 to 50 extra with fitting, if not when it packs up you will have to pay a lot more labour to have your bumper/ front end and timing belt removed again to fit the pump
    Jun 2003
    World of my own
    9,813
    Not to mention possible engine rebuild if the pump has seized and stripped the timing belt.
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    Will Do!
    Thanks for the help
