Chris NottMonster Motorsport
Results 1 to 18 of 18
    Lancaster
    1,629
    Bad condensation
    Firstly. The carpets are dry. No sign of water ingress.
    But when I finish work, the wind screen is drenched. Today it was frozen on the inside. URGH!!
    This is bad news for me, as I'm an on call fire fighter. I need my car quickly.
    Plenum chamber is clear and the plugs are gone.
    Pollen filter is brand new.
    To do: None yet.
    Southampton
    158
    Sounds annoying mate. Ok, you've ruled out the obvious so now id check door seals. When you open the doors (when the problem is apparent) check for moisture ingress on the seals. Eg, no moisture on top or inside the seals? I sometimes think the vents on the dash under the windscreen cause this??!! Try a towel or similar over the vents after shut down? Just throwing ideas at you mate, no definate answer though, sorry!
    munchkincoupe's Avatar
    Aug 2010
    971
    Are your dash vent motors all working?
    Do you have aircon? is it working well? how long since regas?
    Condensation on any other windows or just the front screen?
    Sunroof?
    Lancaster
    1,629
    Front and rear screen. Front is much worse.
    Aircon was charged 2 years ago and gives 9bar when running on vcds. Still gives out cold air in summer.
    All motors have recently been stripped down, reworked and greased. All work smoothly.
    No sunroof. No signs of water in the actual car. It's odd.
    It's not all the time, just with a hard frost on the screen.
    To do: None yet.
    Mar 2008
    1,016
    get some anti fog ..this will stop it happening
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,622
    Bad condensation
    Quote Originally Posted by vr6gordy View Post
    All that will do is make it clear & wet, it won't cure the underlying issue!
    Have you had the windscreen seal checked?
    2009 A3 SB 2.0T DSG S line
    Jul 2007
    765
    Had this on my previous B6 and assumed it was normal in cold weather but my present car has much less.The only thing I never checked was the aircon drain
    Lancaster
    1,629
    It had a new screen in about 2 years ago. But if it was aircon drain blockage or window seal. I'd expect wet carpet or some sign of water?
    To do: None yet.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,622
    Bad condensation
    If the seal is leaking\perished at the bottom, under the wiper trim, you'd probably just get enough moisture come through in wet weather to mist the glass.
    It cant hurt to get the trim off and get in there with a sealant gun to be on the safe side.
    Lancaster
    1,629
    So you reckon reseal along the base of the wind screen? I have some windscreen sealant... hmmm
    To do: None yet.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,622
    Quote Originally Posted by BlackQuat View Post
    that's the job half done then. lol
    pink.teg's Avatar
    Jan 2012
    Cardiff
    170
    Hi m8
    im sure another , has written about this coz I had that 3/4 days ago and changed the pollin filter
    2 min jobs and its all good now .. Have ago
    best of luck
    alan
    Quattro Jam B12 suspension kit ,Custom Droplinks F/B , HID 6000, 18" RS4 Alloys, summer AMG's .
    RS6 for Show's .Cat gone for walkees, sports six padded clutch DMF
    Remapped 173BHP///278lbft, RS4 F/R ARB's , happy with that ........
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,413
    He mentioned the pollen/cabin filter is brand new unless it has not got a proper seal when put back together.
    Mike
    Lancaster
    1,629
    Is it possible for the filter not to seal? It doesn't seem like it would seal tbh.
    On a good note, it passed it's MOT today.
    To do: None yet.
    Jun 2011
    Great Melton Norfolk
    1,340
    You do have to be careful to get the filter in place and the seal/clips back in place.
    Lancaster
    1,629
    It never looks like it seals though. Just sits in with a cover?
    To do: None yet.
    Jun 2011
    1,340
    The cover has to locate at the back and lock in at the front to seal properly.
    Lancaster
    1,629
    I'll double check that tomorrow. Cheers.
    To do: None yet.
  1. Audi Dealer good or bad?
    By colinreid in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2003, 13:14
  2. warning bad taste s3....
    By rockstar in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2003, 18:20
  3. chipping a 1.8t bad for engine?
    By twally in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2003, 03:58
  4. Bad and the good
    By will_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2003, 18:50
  5. Condensation?
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2003, 14:14
