Results 1 to 16 of 16
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,186
    S4 with 60-70k, what to look out for?
    What should I be aware of at that kind of mileage? Any issues with the 4.2 lump?
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Timing chain rattles, excessive oil usage they do use lots and prone for it
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,186
    Re: S4 with 60-70k, what to look out for?
    When does the chain need replacing, and what's the problem if it does rattle?
    Jul 2011
    mids
    1,193
    Chain tensioners have heard its a engine out job and can cost £3000/4000 hopefully someone who owns and done the research on them will answer this thred better as I've never owned one.....
    A4 TDI 130 SPORT..
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,704
    Timing chain change comes in at 180k from memory, and its an engine out job as mentioned.
    BRILLO's Avatar
    Sep 2011
    Juniper Green, Edinburgh, United Kingdom, United Kingdom
    135
    i know of a guy with one that spent the 3+grand to repair and it still rattles a bit.(in my opinion) maybe its what they do. nice motor though.
    colinurquhart's Avatar
    Jun 2009
    200
    The S4 never needs the chains replaced unless due to failure. I've not heard of one failing due to the chains, it's always been due to the chain guides or tensioners and quite often it's due to the car being on a long life service plan which is no good for these engines. I change my oil every 5-6k with a good quality oil. The engines are very reliable and failure is very rare. The start up rattle is normal for these cars as the tensioners work on oil pressure and this only comes once the engine starts up. Audi have stated that the rattle should last 1-2 seconds, if the rattle continues then walk away as its an engine out job. They also consume oil so always keep an amount in the car as backup and check the level regualarly. Oil change on these cars is so simple. There's a clip on YouTube of how to that I'd recommend you watch. I'd certainly recommend one if theses cars. I've had mine 18 months and can't fault it. I went for the B6 rather than the B5 over reliability and that's me done 20k miles since I've bought it, including a track day too. Be prepared to fill up regualarly as thy drink fuel for fun. I had mine converted to lpg in August and that's helps as I do about 400 miles a week. Hope all this helps.
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,186
    It does thanks
    dsmclark40v's Avatar
    Sep 2006
    Hampshire
    715
    Mine failed because the chain stretched. But that was because the tensioner snapped. Cost a little over £5000 as the exhaust valves all touched one side and the inlet manifold was also making a noise so they changed that too (that on its own was £1000) luckily I had a warranty. Mine still rattled after the work was done thought. It would stop after oil changes until I had done about 3000 miles so I use to change my oil at the 3-4000 mark. Try and look around the engine for oil leaks as they tend to leak around the rockers. Watch for smoke on overrun as this can be a sign of scorn cylinder walls. Check all the windows go up and down as they should as the regulators are prone to failure. Also watch out for a slight judder when pulling away as that will be the dual mass flywheel on its way out, at that sort of mileage if its still on its original clutch it might be time for a new one anyway. Make sure its had the coilpack recall and has been maintained well i.e. not on longlife and genuine parts used and you should be alright
    Sam,
    Gone
    Mar 2008
    Dorset
    13,704
    Quote Originally Posted by colinurquhart View Post
    I'll bow to your greater knowledge, but I've heard before that it does require replacement. Although I can't remember where from, or how reliable it was likely to be.
    brasiliangringo's Avatar
    Mar 2010
    496
    I very much doubt its a service item given the cost involved - i read its $3k us from an American site in parts alone..
    Jun 2009
    200
    It's meant to be a 30 hour job, engine out as chains are at the back. I wouldn't worry too much about chain failure. Just make sure the cars got a good service history and hopefully not on long life service. Saying that, whatever one you go for just make an oil change the first thing you do.
    Inertiauk's Avatar
    Mar 2011
    529
    MY chain rattle comes back when my oil is about 1/2 way down the dipstick between min and max, top it up again to max and it disappears. However these cars burn a fair amount of oil, so you end up doing it fortnightly or more depending how you drive it.
    Using thicker oil is best too, when I was on Castrol Edge 5w30 it rattled a lot more than the 5w40 TPS (Quantum Platinum or something I think) oil I am using now, this also reduced the amount of oil it burns.
    Ask for the car to be cold when you view it, start it up with the door / window open so you can listen for hte rattle, IMO if its 3 seconds or under then its fine and you can cure it with thicker oil and keeping it at max, if its much more than that the tensioner or guides are faulty, or the oil in the car is very thin, very old, or very low.
    The rattle is a bit scary but its very rare that the engines fail because of this.
    I would recommend listening for clunks and clicks whilst steering at low speeds, a set of front arms isn't cheap and it can involve a lot of labor changing them ,if it clicks / knocks you might be able to knock that expense off the cars sale price.
    I ended up changing all the arms on mine. But it has done a few more miles than this one.
    Good luck.
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
    Jun 2011
    213
    leaking aux rads is very common and the starter is quite prone to playing up. i had faulty tensioner and snapped guides and ended up changing the whole lot as well as clutch/flywheel, various sensors and rebuilding the starter! still love it though!
    Mar 2009
    449
    On top of everything already said, check the air con is working correctly as the compressor is costly to replace.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,186
    Just a few things then lol...
  1. What to look out for when collecting new car?
    By SMc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st October 2007, 09:53
  2. What to look out for in used C5 A6?
    By madchef in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th March 2007, 21:40
  3. what to look out for 2002 2.5TDI SE
    By 69COU in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th December 2006, 21:44
  4. Looking for a used A3 - what to look out for?
    By jrsp in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2006, 22:18
  5. what to look out for when buying a a4t sport ??
    By danp in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd November 2004, 03:22
