Monster MotorsportEM Tuning
Results 1 to 9 of 9
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Exclamation Alarm going off constantly - URGENT
    Hi all.
    My damn alarm keep going off for (seemingly) no reason and is peeving me and the neighbours off.
    Had problems with doors freezing shut this week so am wondering if this may have affected something?
    Also had the 3-4 beeps coming from the rear alarm unit recently, although that stopped a month or two ago with the alarm being unaffected.
    Finally, I have had water in my bootlid recently, could his have frozen and damaged something?
    The picture of the car on the dash does not show any doors as open, altough it does flash up with the whole car (with no doors open) which I'm not sure I've seen before?
    Any swift help appreciated.
    *WANTED* AUDI CD PLAYER
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,534
    Quote Originally Posted by AVANT130 View Post
    That means the alarm backup battery is now totally flat, which could be the cause of the alarm keep going off. Sort that out and see if the alarm starts behaving properly.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Dec 2012
    36
    If you had water in the tailgate lock then normally this would indicate that there is a door open on the dash as the micro switch wouldn't see the boot as shut? these are more common for the n/s/f foot well gettin water into the block connectors causing for corrosion as these are the same set up as the 3b chass passat and having worked for vw i know all about it hope this helps?
    Oct 2012
    492
    This is usually the sign that you have water in the floor it comes in from under the windscreen had this with my past just google passant and a4 water ingress very common fault there are two drain holes under the battery under screen they block up and water goes down round poll on filter and comes out under passenger seat out of the vent in the floor check rear passenger side carpet mine was soaked and your comfort control unit that controls all electrics is under there and it gets into it and sets alarm off all the time if this is the case you need to sort it and dry it soon ass cos they are expensive
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    So at this stage I think it's either tired alarm batteries, or water in the tailgate causing it to think it's been opened when it hasn't.
    Will get it on VAG-COM asap to see if there are any codes.
    Anyone have a part number for the Avant bootlid seal??
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    worth a try, but in your drivers door are the 2 switches, try activate them 1st before you lock your car up, see if that makes a diff,
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    The alarm system should also store fault codes for you to read.... You could activate the 2 switches to see if this stops it at least then you get a picture if its a interior inside problem of the alarm itself
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    pauldazzle's Avatar
    Cardiff
    639
    I had exactly the same on an A3 Quattro, & it was the alarm siren batteries that had leaked onto the pcb board. Bl**dy thing kept going off in the middle of the night, nearly had my neighbours forming a lynch mob
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    colinurquhart's Avatar
    Jun 2009
    200
    Quote Originally Posted by pauldazzle View Post
    Yeah my B6 S4 was the same, a leaky battery.
  1. alarm/hazards going off constantly
    By argyle89 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2012, 18:35
  2. Alarm going off in rain ?
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2006, 01:48
  3. alarm going off
    By paul_brad in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2005, 13:47
  4. Standard alarm going off without siren!!
    By imported_2219 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2005, 23:44
  5. Alarm going off for no reason
    By schuumi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th November 2004, 13:09
