    Apr 2012
    Lanc's
    9
    A4 18t started ticking over at 1400 revs help pls
    Hi my 190 18t started ticking over yesterday morning at 1400 revs now doing it constantly
    i have plugged in works snap on solus diagnostic no codes present so have been advised its throttle position sensor
    i have priced this up there £400 don't want to miss diagnose
    stripped down housing the sensors all one with the housing cleaned refit still same
    phoned dealer there solution book it in for a plug in £105 thanks
    could this be connected to my temp sensor on dash still not working I recently replaced thermostat housing and temp sensor in lower pipe
    really enjoying this money pit NOT pls help thanks Si
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Get it scanned properly coolant temp sensor can cause revving up when starting, so it could be a simple cheap fix £20-30
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Aug 2010
    1,540
    did you check the actual values on the position sensor with the diagnostics?
    doubtful its that tbh.
    vac leak or pcv valve more likely if you have no fault codes.
    Apr 2012
    Lanc's
    9
    Engine management light finally came on earlier hopefully not telling me I unplugged the throttle body gonna try me blue point diagnosis tool Monday then worset to worst dealer it is
  1. Tick over starting issues . Bam motor mgzs180
    By Sneekyparrot in forum Volkswagen and other VAG
    Last Post: 17th August 2012, 08:53
  2. ENIGINE MISS FIRE N CAR VIBRATING ON TICK OVER 2.5TDI V6 HELP!!!!!!!!!!!!!!
    By johnswales in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th December 2011, 20:32
  3. Tick over and starting
    By audia3vwgti in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2009, 15:31
  4. Replies: 12
    Last Post: 19th May 2004, 11:06
  5. tick over
    By dwarfslapper in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2004, 18:01
