EM TuningChris Nott
Results 1 to 19 of 19
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Question Water in Avant boot lid
    Hi all.
    There is water getting into my Avant boot lid that seems to have got there via the heavy rain we have had. When I raise the bootlid it drains away quickly. Water can also collect on the rear retractable cover over the boot space.
    It is not due to the rear washer pipe as I have not used the rear water, any ideas anyone?
    *WANTED* AUDI CD PLAYER
    May 2012
    Kings Lynn
    911
    No idea but i have the same issue with my rear passenger side door...leaks into the car onto the seat and really fks me off!!! after heavy rain also. all the seals appear fine etc so i dont know I gave up looking and trying lol
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition, Unicorn stage 1 remap, Metallic Dolphin Grey, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights, HID 6k, RS 4 pedals, Rev D D/V, APR snub mount, NGK 7s
    Gone - 2005 B7 A4 Avant 2.0 TDI
    Nov 2011
    South Lanarkshire
    81
    I've got the same problem.. Looks very like the water is getting in thru' the seal on the high level brake light..
    M
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Is it a replaceable seal??
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Anyone solved this problem before?
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Surprised that no-one has had to do this job before
    Oct 2012
    492
    are you sure its not getting in round pollen filter under windscreen then traveling down vent to rear passenger footwell very comon fault with passat and a4
    Nov 2011
    South Lanarkshire
    81
    Hi there, sorry I've taken so long to reply.. I just replaced the whole light unit as mine had a few cracks and broken bits on the top side of the light.. As hard as I tried I couldn't remove the unit in one peice.. I would try some clear silicone round it to see if that solves the problem. If it does you then know the culprit.. Good luck.
    M
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Quote Originally Posted by southylad View Post
    Thanks for the reply but it's in the bootlid
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Could it be coming in via the bootlid hinges??
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Quote Originally Posted by AVANT130 View Post
    Anyone?
    Greeny233's Avatar
    Mar 2011
    Llangollen
    702
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    I'd sit in the boot and get someone with a hose to soak the car and wait for it to start leaking. That'll show you where it's coming from.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    Aug 2011
    199
    Almost certainly the seal round the high level light - it's such a faff getting the rear trim off incidentally. I suggest using "dum dum" compound rather than silicon. It's a non setting, black sealant which is used on Land Rovers and other British cars in a variety of contexts. (Search "dum dum sealing compound"). It's generally used as a leak stopper - something all LR owners will be familiar with!
    Take a blob, roll into a thin sausage, force into the gap. I've found an old credit card to be helpful, and the round corner helps give a smooth, neat finish. Clean residue with white spirit or turps.
    I had a similar problem - this solved it. Dum dum is very useful for all sorts of other little jobs where you want a sealant which remains flexible and won't dry out / go hard and brittle.
    Mike.
    Nov 2011
    South Lanarkshire
    81
    I was replacing my rear wiper arm today and it looks like I've found another possible source of the water ingress into the tailgate..after trying my rear wash wipe I noticed water coming out from the rear wiper motor.. Ill strip it out and see if I can find the source of the problem..
    m
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    I reckon water must be coming in at a higher level on mine as it is dripping onto the rear parcel shelf, so I'm thinking the the high-level brake light might be allowing water in?
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    So, bootlid interior trim removed today and it looks as though water is coming in at the high level brake light. Having removed that and inspected, the seal on it looks pretty rubbish so will refit with some form of semi-permanent sealant. Can't seem to find dumdum anymore, anyone know of a suitable way of sealing the light unit that wont leave odd streaks down my car when it rains
    Aug 2011
    199
    Hmm - it seems Dum Dum is no longer produced. Sorry about that - -
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Quote Originally Posted by Mike_B View Post
    No problem! Thanks for the heads up anyhow
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Anyone know of a suitable sealant?
  1. Avant boot lid light and boot ceiling courtesy light...
    By DALE_AVANT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th September 2013, 18:05
  2. Avant boot lid issue's
    By OldRedEyes in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th January 2011, 19:09
  3. A4 2.0TDi S-Line Avant - Boot lid wont stay up
    By path2 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th October 2009, 10:48
  4. Avant boot lid electrics
    By dope in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd November 2008, 11:18
  5. Avant boot lid non-closure
    By dan_b in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th October 2007, 00:56
