Volks AutosMonster Motorsport
    Mar 2012
    47
    Denied Revo tune -P0441 code
    Went to get a stage 1 uploaded this morning. I scanned the car a few weeks ago and was error free, but wouldn't you know it the car threw a code today during the pre-check. The tuner won't progress until I get it fixed as it might aggregate the fault.
    I don't have any CEL or symptoms other than the code itself.
    16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
    Possible Causes
    * Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
    * Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
    * Evaporative Emission (EVAP) Canister Sealing faulty
    * Pipes between Tank Breathing and Throttle Body leaky/blocked
    In what order should I be tackling this? N80 valve looks easy to replace so maybe I should be starting with that? If anybody has some easy checks / tests I can do (I have VCDS) to help trace it I'd be very grateful.
    Mar 2012
    47
    ..in fact I changed the N80 Evap purge valve about 5k miles ago! Any way to test it?
  1. revo or custom code
    By coatesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2011, 15:01
  2. Which Remap supplier? (Revo , Superchips, Custom-Code)
    By g60leigh in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2010, 18:25
  3. REVO or Custom Code???
    By StevoS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2010, 16:08
  4. S3 Tuning - Custom Code
    By Dazzeroo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd August 2009, 10:23
  5. Revo or Custom-Code
    By S3-Chris in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2008, 18:17
