Monster MotorsportVolks Autos
Results 1 to 8 of 8
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    What are the signs of steering rack issues?
    I am sure i put brake fluid in the powersteering res by mistake when i first got the car
    Having a few issues with the car pulling left and right and booking it in for all the arms changing on the front before i get 4 wheel alignment done
    Im just concerned i may be fixing the wrong thing, everywhere i take it cannot tell me where the issue is
    There is a clonk almost everytime i set off or brake
    Maybe its this arm, or this, or this... and ive taken it to 4 different places
    ("difficult to tell on audis as the have so many ball joints" !!)
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    Jan 2012
    Warrington (NW)
    118
    Dosn't sound like the steering rack through wrong fluid, Typical symptoms would be leaking fluid, notchy steering or play in the inner track rods which could make a clunking noise when moving the steering wheel left to right. Not really the sort of noise that would occur everytime you set off or brake.
    The suspension on these cars can be a pain in the arse to work on !
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Could be the bottom arms that's what I'd be checking first anyway..... But you may need it tracking up again if you change things
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Sep 2009
    Rumburgh Suffolk
    175
    Mine started that immediately after fitting Bridgestones on the front, torque steers like a b!tch. (pulling from side to side that is..)
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    Lancaster
    1,654
    I found that when my rack and pump were failing, the pump would occasionally pressurise and knock the steering abit.
    To do: None yet.
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Hmmm
    Sounds like mine is ok then. Just need to get the full kits for the front arms and change the lot in 1 go
    Cheers for the adivse on it being the bottom set Mark, but im worried it might be one of the other ones
    If i do change 1 set and im wrong, then it will cost more in the long run... Time to bite the bullet and go for the kill
    £120 quote to change the lot from my local garage... Just need to buy the kit myself
    Jul 2011
    mids
    1,193
    I'd say get some ramp so this allows the car to sit at ride height then get a bar in the bushes see if there any signs of play, If they was that bad then you would probably feel some knocking aswell.....
    how long it been doing this ??
    when did you get the tracking done as if this as been set up wrong it will give you sights of unsteadiness on the road
    A4 TDI 130 SPORT..
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Quote Originally Posted by marktdisport View Post
    Never had the tracking done and it started months back
    It does drag left and right as though its gripping the changes in the road. It also seems to pull left slighlty most of the time, then sometimes to the right.. I'm guessing it dependant on the surface/quality of the road
    Wanting to get it tracked, but dont want to spend £40 (ish) on tracking just to have to change the parts knocking, then re track/align
    Tyres seem to be wearing even on the front, but rears are wearing quickly on the outer edges (bushes on the rear gone maybe or not aligned)
    It's one of those, do i try the cheap option of tracking or go the full hog...
    A few places have had it up on a lift and cannot work it out (not found a place that would touch the tracking yet, just get the answer that they are tricky/difficult and only the stealers can track)
  1. What are the signs of a faulty coolant temperature sensor?
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st February 2012, 18:52
  2. What are the signs of a faulty or worn MAF?
    By CHRIS555 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th January 2011, 00:47
  3. what are the signs of knackered suspension springs ..?
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2010, 17:28
  4. What are the signs of a weak actuator?
    By feville in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2010, 20:53
  5. what are the signs that you need a new turbo?
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2006, 20:34
