    Sep 2010
    498
    1.9tdi PD130 - Alternator pulley replacement
    I had to replace my alternator clutch about a year ago now after it seized and caused some horrible noises and steering feel. The new one seems to of failed again! I have now bought one from GSF (I think the current one was from someone on ebay, new but not sure if it was OEM). I can't seem to remember if the nut to remove it was a reverse thread or not. I remember it being very tight, but I would like to be turning it the right was in order to loosen it off!
    Any help would be immensely helpful!
    Oct 2012
    385
    If you are using the correct tool that holds the shaft in still whilst you undo the pulley then it's a normal thread, and yes they are on
    well tight when seized, i had to angle grind one off in chunks
    Sep 2010
    498
    Ah right thats good to know. Hopefully it won't be on that tight as I replaced it about a year back. I did use a breaker bar and even then it was tight as a mother...
  1. Alternator pulley seizing !
    By markpw73 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th February 2010, 18:54
  2. Engine Idle issue with A3 1.9TDi PD130
    By michaelab in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2009, 14:37
  3. What Wheels on Audi A3 Sport 1.9TDI PD130
    By Mason-A3Sport in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2009, 21:00
  4. Real 0-60 of a 1.9TDi (PD130)
    By Toxik-Signal in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2007, 22:32
  5. 1.9TDi PD130 suspension upgrade
    Last Post: 7th November 2006, 18:14
