Badger5Monster Motorsport
Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By stu_m
Thread: Which Coolant?
    May 2012
    67
    Which Coolant?
    Which coolant do I need for a 1.9tdi 130?
    Had a search but couldn't find anything, anyone help?
    Jun 2012
    Teesside
    448
    G12 mate your coolant expansion tank or cap should have it on somewhere, im sure mines on the cap
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,160
    G12++ has been discontinued, it is now G13 which can be mixed with G12.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Oct 2009
    Hull
    1,442
    Re: Which Coolant?
    You can use any that conforms to vag spec but if you do you need to drain and flush the system
    Apr 2012
    202
    If you have any of the G12,G12+ or G12++ in the system your ok to top it up with G13. There all mixable.
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    642
    Re: Which Coolant?
    Volkswagen tends to change their coolant a lot, but theyre all backward compatible though
    Jan 2012
    Warrington (NW)
    118
    Red stuff (longlife) drain your old coolant and put some red coolant in. Some last 5 years, some are 10. Once it's done you can forget about it.
    May 2012
    67
    So just the red longlife stuff will do? Doesn't have to be a specific vag coolant?
    Apr 2012
    202
    Just make sure what you get is the red stuff for VAG group cars. If the car all ready has the correct coolant in there is no need to drain the system Tue coolant is designed for the life of the vehicle.
    Jan 2012
    Warrington (NW)
    118
    Well why are you adding coolant? is it just a top up or are you doing a system flush?
    If you are flushing the lot out then you can put what you want in. No it dosnt have to be VAG specific. You need to see what the coolant contains, Ethelyne glycol is usually the Red stuff and lasts 10 years, I would reccomend that and it's available from any motor factor. Just dont mix blue coolant with red as they dont go together
    Feb 2009
    Aberdeen
    2,623
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Head to the stealers and get a bottle there. It might be a quid more than you can get elsewhere, but it'll definitely be the right stuff. I think G13 is the new VAG-wide standard additive. Make sure you dilute it properly too, don't just pour the stuff straight into the tank or you'll damage something expensive.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Jan 2012
    Warrington (NW)
    118
    like i said, as long as it's the same colour, throw it in.
    full flush you can re fill with anything but needs to be a 50/50 ratio
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    I've never seen a thread with so many opposite comments on what to do, for sake of a few quid would you want to run the risk of using the the red stuff if there somethink in it which could be proven to eventually corrode or rot you cylinder head or block who knows the answer over a short term probably no issues, but can't believe people can't be arsed to buy proper vag coolant for probably a few quid more........
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Oct 2009
    Hull
    1,442
    this is what I use TRIPLE QX Red Anti Freeze 5Ltr
    and as it says
    It is suitable for any vehicle currently using Redantifreeze / coolant and meets GL12+ Standard
    Apr 2012
    202
    As I work for VW some of the replies in this thread are starting to amuse me. VW state that the G12,G12+,G12++ and G13 are all mixable. Correct ratio is 3 parts water to 2 parts anti freeze for protection down to minus 25 celcius fine for this country. Also the proper VW stuff is supposed to he mixed with dostlilled water not regular water for it to last life of the vehicle.
    Jan 2012
    Warrington (NW)
    118
    Quote Originally Posted by marktdisport View Post
    That is why I advised to drain the lot out if it because the corrosion inhibitors wear off after a while and fresh coolant is always good for the car. I personally would not use the cheap stuff from lets say, Tesco. I always use the longlife "RED", but I dont see what your point is If it isnt from VW ? You can buy non VW coolant which works just as good and compatible.
    Quote Originally Posted by Ian-83 View Post
    Glad to hear it. Just double checked online, and like I thought every coolant I have seen says Vw/Skoda/Audi/Seat compatible, then Ford Vauxhall etc.
    At work we use Quantum Red Longlife,which is the VW brand we get from TPS, and that goes in everything not just VWs. The small Comma branded tubs we sometimes have in Red are also compatible with this G12, So therefore I would want to save a few quid by not buying from the dealer. In my case I saved quite a bit I bought a big 25l tub of longlife on offer from Lookers Vauxhall rep for £33 and like the rest it's compatible, So I would say topping up with Red would be safe, IF thats is what is in his car. If it wasn't or if there was no record of a coolant change in the last few years then I would be draining and flushing the lot out with the hosepipe. But each to their own
    Roughly 50/50 of quantum will give me -25 on the hydrometer, as long as theres between 2 and 4 floating on a service then it's good to go
    May 2012
    67
    I don't know what's in it now, it's brown an dirty. Think I've got some longlife in the garage so ill see if I can find it. May aswell do the stat at the same time.
    thanks everyone
    Nov 2010
    81
    Hi mate Eurocarparts does some for bout £15 i just bought some a few days ago
    Jan 2012
    Warrington (NW)
    118
    Quote Originally Posted by Kyle. View Post
    thanks everyone
    may aswel mate, not expensive at all. bleed it up at the same time instead of doing it twice !
    brown and dirty is not good, signs of rusting that is. run some radiator flush in it for a bit, it says run for 10 minutes but I'd give it a bit longer than that, drive round for a bit let it really get to work.
    Although not reccomended , on my old Escort the heaters went really weak one winter, changed the stat as that appeared at fault but wasn't right still. Bought some wynns radiator flush from halfords after work and poured it in then, drove 5 miles home, couldn't be bothered to drain it when I got home as I was knackered, then drove 10 miles to work next day, then back home again and then I pulled my finger out and flushed it....It came out black ! Blasted the hose pipe through the matrix pipes and everywere else until it was clear. Heaters perfect after that.
    Although mine was blocking and the water looked fine, rust from the radiator or matrix floating round can also cause a blockage and just shows that the coolant has lost it's anti corrosion properties through being in there for too long hence the brown ****ty looking water.
  1. coolant temperature sensor 1.8t agu which color?
    By 1.8T_ in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2012, 17:25
  2. Which coolant should I buy from Halfords
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2012, 02:16
  3. Which coolant
    By A3Bash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2010, 13:53
  4. Quick Question, which engine coolant?
    By makavelli in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2010, 22:37
  5. Which online digital photo printer do you use?
    By danksy in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 5th January 2003, 16:00
