Johnboymason
hi has any1 had this problem with b6 audi a4 when i feel under glove box in footwell is wet only notcied as we have had alot of rain over the poast few days
Think i mentioned this the other day, but.... Sounds like you have blocked drains in the bulkhead where you battery, servo ect.. Sits.
Had similar symptons in my b5. Went to drive off one day and noticed drips of water running down on the carpet from behind(ish) the glovebox. After the initail what the f**k moment had a look in and around where the battery sits (remove plastic lid/cover) saw a great big trough of water!
Took, the battery out, had a prod around and the drain holes were blocked so water collected rather than draining. There were rubber bungs in the hole which i removed/pushed through then all the water gushed out underneath the car.
thankshttp://www.audi-sport.net/vb/a4-a4-...assis/159907-help-water-drivers-footwell.html
http://www.audi-sport.net/vb/a4-a4-...assis/163784-water-ingress-into-footwell.html
http://www.audi-sport.net/vb/a4-a4-...ssenger-floor-soaked-front-slightly-damp.html
http://www.audi-sport.net/vb/a4-a4-...wells-swimming-pool-but-not-plenum-plugs.html
http://www.audi-sport.net/vb/a4-a4-...s/162449-water-sloshing-around-somewhere.html
http://www.audi-sport.net/vb/a4-a4-...-every-a4-b6-owner-affected-common-fault.html
I'd check the plenum chamber, but drivers footwell may be more likely to be the ecu seal. There's guides on here as to what to remove to open the ecu box, and you'll see whether it's that. My b6 has had a wet drivers side recently, but passenger side is dry as a bone.
Hi where is the guide located
