Chris NottEM Tuning
    alcoholic pervert
    Nov 2008
    Chalford - the Cotswolds.
    181
    Coolant escaping - 1.8T 190
    Hi.
    I've been loosing a bit of coolant recently. Not loads, but enough to get it sorted.
    Temp stays dead on 90 as it should, and I had a new metal pump a couple of years ago. There's no water in the oil and there's no oil in the water.
    I had a look to see if I could spot where it's getting out and found this
    which is located here
    And I think that looks suspicious.
    My questions are - do you agree? And what is that bit called?
    Thanks!
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    Yep thats suspicious, you can see where the G12 coolant has chrystalised to try and prevent the leak.
    I have no idea what the part is called but hoses perish with age so could have split slightly at the end, probably best replacing it.
    alcoholic pervert
    Nov 2008
    181
    Cheers - I'm guessing the number 068 121 101 A on the lower hose is a part number?
    Hard to tell which hose is to blame since it's oozing out of the coupling though...
  1. V6 coolant temp sensor & idle speed control valve
    By JDA in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2004, 18:27
  2. S3 Coolant warning
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 21:02
  3. Coolant Temp Sensor
    By teknobod in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd January 2004, 11:14
  4. Coolant pipes
    By Seizure in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2004, 23:10
  5. 190 speeding ticket..............................
    By Gambba in forum General Chat
    Last Post: 14th April 2003, 13:41
