Sky InsuranceEM Tuning
Results 1 to 7 of 7
    SL11 CKK's Avatar
    Drop Gear
    Apr 2011
    405
    Is my cutoff line OK?
    Just a quick one folks!
    I just realised couple of days that my cut-off line has 2 steps.
    I swear it should be just the one step; right?
    Oct 2009
    Hull
    1,245
    Re: Is my cutoff line OK?
    Both lower lines should be level so the left is too high or the right is too low
    Don't try and correct them yourself take it to an mot place its far easier
    Lancaster
    1,395
    On flat ground, i'm sure the line should be same height as the bulb from 10meters.
    Something like that anyway.
    To do: None yet.
    quattrojames's Avatar
    Mar 2008
    Dorset
    12,591
    Looks like the nearside light is set a bit high. The "line" of the lights should be the same height for both, and it will obviously kick up on the left for a lhd car.
    Their very simple to adjust, use the inner most adjuster (parked facing a wall as you are) and either raise the offside light, or lower the nearside one.
    2003 A4 Avant 2.5TDi quattro
    Ingolstance
    SL11 CKK's Avatar
    Drop Gear
    Apr 2011
    405
    Im going to do this hopefully tonight. Ill use the lines between the bricks as a rough guide then off to MOT to check if its within the range.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,657
    my 1st view says your right side is too low and your left side is ok, get it to an mot place and get them to level them up for you,
    Oct 2009
    Hull
    1,245
    Oh and make sure your headlight range adjuster is on 0 before they are set up
  1. Can't Clarkson keep a car in a straight line???
    By Pegsta in forum General Chat
    Last Post: 1st January 2004, 23:27
  2. A3 3.2 S-line information from Audi UK
    By scoTTy in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th December 2003, 22:18
  3. Turbo Oil Lines
    By BarryT in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th October 2003, 22:29
  4. S-Line ??
    By tvr1 in forum General Chat
    Last Post: 6th August 2003, 15:29
  5. Barclaycard Direct / Direct Line - Modifications
    By Dylarolla in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2003, 13:56
Tags for this Thread
