Sky InsuranceJMB Retrofits
    Apr 2011
    welling
    24
    Cam adjuster gasket
    Hi there, I have an a4 1.8t sport I had the rocker gasket changed but just noticed on a report from 4 rings that the cam adjuster gasket needs changing is it an easy fit?
    Thanks in advance
    Mar 2012
    57
    Good news first. Yes, in itself it is very easy. Takes about 10 minutes and anybody could do it.
    The bad news;
    • 90% of the work is taking the rover cover off (which you've just done and put back on)
    • You need a special tool to compress the tensioner piston
    The tool costs 2-3 quid, and allows you put enough give on the chain to lift the tensioner assembly just high enough to slide the old gasket out, and pop the new half moon seal in underneath that. The gasket (and half moon) costs about £7 from TPS.
    Part No. / How to here;
    PART NO.
    058 198 217
    HOW TOHow-to: 1.8T Cam Chain Tensioner Gasket replacement
    Apr 2011
    welling
    24
    That's good to hear thanks for your valuable advise is the special tool easily available?
    Mar 2012
    57
    eBay was the only place I could find it. Audi dealerships might sell them, TPS don't. They're cheap on eBay anyway.
  1. rocker cover and cam chain adjuster gasket part no....
    By superkarl in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2013, 12:44
  2. Cam Adjuster Gasket.
    By jamin in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2011, 19:18
  3. Cam adjuster Gasket, Cam Cover Paint (Pics)
    By S3 TAM in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2011, 23:58
  4. Cam cover gasket?
    By Randomjim in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th June 2008, 17:30
  5. Cam adjuster seals (may have a different name...)
    By cbass in forum General Technical / How To
    Last Post: 20th September 2004, 20:37
