AH FabricationsBadger5
Like Tree1Likes
  • 1 Post By adamss24
Thread: ARE TDI's LIMITED MODIFICATION
    Oct 2012
    Wigan
    178
    I have always owned turbo petrol cars or petrol cars that can be modified, How good are the engines to modify on the 2.5 tdi's can the intercoolers be replaced with one big on, turbo upgrades and injector, but what will the actual engine and box take safely
    Right now it just has a performance panel filter not into the cone, and dim development remap taking to to about 215hp
    I know the list is endless with the body modification etc
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    I'd not mess to hard with the 2.5 mate. disconect the EGR valve sucker pipe and block off the pip so the system does not lose its suction presure,
    Oct 2012
    Wigan
    178
    ive done that but left the vac pipe connected should i remove it
    Jul 2007
    London
    3,211
    The block will take 500 Bhp, getting 500 Bhp out of the engine is a different story ! Yes to all your questions, you can upgrade intercoolers, turbo and injectors and get beyond 350 Bhp with a very, very good map. Early models had better pumps without being limited electronically, also b6 2001 had all alloy intercoolers and a different trim of the turbo so they run higher boost. With the stock turbo you already reached the limits of the GT2052 so you either need a hybrid or adapt a GTB2260vk. Add power plus 683 nozzles or race 683 nozzles and remap to take the changes into account and you'll have a fire breathing monster. I have fjtwelve old a6 tdi which i bought with a broken engine. After porting the heads, replacing the valves, balancing the race 683 nozzles, adding a allroad intercooler (all aluminium) and a gtb2260vk i can say it's a monster... I had to replace everything though: brakes, suspension, bushes, antiroll bars and much, much more ! I would take the engine and put it into a lighter car though, perhaps a b5 tdi quattro as it handles better than the a6 platform and is 3ookg lighter. That would be a drive to remember !
    Neilb1 likes this.
    FOR SALE:
  1. Allroad 2.5 tdi 2005 limited edition parking sensor colour code.
    By mickel5 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th March 2012, 11:11
  2. A4 2.0 TDi economy, what are people getting?
    By pin in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd July 2008, 14:05
  3. What oil are you using in your TDI?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2006, 22:04
  4. Question for those that are Tdi's, chipped with DSG
    By marriedblonde in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th January 2006, 13:18
  5. Question for TDI drivers: what diesel are you using?
    By ginner in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st March 2005, 14:09
