Chris NottSky Insurance
Results 1 to 22 of 22
    lincoln_dj's Avatar
    Dec 2009
    Lincoln, England.
    137
    water / condensation inside windscreen (B6 A4 S4)
    Hi Guys,
    have had a quick search and can't find a great deal about this other than the usual blocked pollen filter & blocked battery drain holes.
    Just wondered if either of those would cause the amount of water on my screen? It took a good 12-13 minutes to clear this morning with full blowers, ac on, etc. Can see this water freezing in the not-so-distant future. I'm loathe to wipe it off as you then get wipe marks until you clean the window properly...
    So just wondering if this is as bad as other peoples and if so, did changing pollen filter or anything else cure it?
    No comments from idiots telling me theirs is fine please - not had this issue in the last 14 years of driving so it's definitely the car and not how i drive or use the hvac!!!
    pic...
    2004 A3 3.2 V6 manual
    kite's Avatar
    Oct 2007
    East Berks
    660
    Re: water / condensation inside windscreen (B6 A4 S4)
    Is it blowing on to the screen, looking at the picture I would expect the centre to clear first.
    I had this with mine and the air distribution flap motors was stuck.
    Think there's a how to on here somewhere to free up the motor.
    A4 (b6) 2.5 TDi QS Saloon.
    Apr 2012
    46
    I have the exact same issue my friend...
    Awaiting to see if anyone replies with some good advice/tips
    lincoln_dj's Avatar
    Dec 2009
    Lincoln, England.
    137
    Quote Originally Posted by kite View Post
    this is when I first come out to the car in a morning. if fully steamed up the centre does clear first as expected. Makes me wonder if the moisture lives under the centre vents somewhere... Air definitely comes out the centre vents.
    Nov 2012
    160
    Drain holes blocked for sure.. Replace filter as well..
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,417
    I had this and so did my wifes mk5 Golf.
    Changed the pollen filters in both and the problem disappeared completely. I was amazed at how clogged they were with mouldy green/grey stuff and could not have been changed in a while
    Mike
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,417
    Also is there water in the chamber below the car battery? If so make sure he rubber plugs are taken out so the water can drain out as they block all the time.
    Mike
    lincoln_dj's Avatar
    Dec 2009
    Lincoln, England.
    137
    thanks guys i'll check near the battery. also getting oil n filter change next weekend so i'll get pollen filter too.
    wahlstrom - which drain holes do I need to be checking?
    All carpets etc are dry, although when I open rear offside door there is a little water on the sill plate (where the S4 ally plate is)
    Southampton
    158
    Had a similar problem on my b5, the bulkhead where the battery sits was about 3" deep in water! Battery out, stab around with a screw driver till you find a drain hole and unblock. It will all gush out under your car and form a big puddle!
    I have similar issues with my rear window at the moment, very annoying first thing in the morning.
    Nov 2012
    160
    Drainholes under battery(you have to remove it to get to it) and beside the ecu.. Remove the rubber in the hole.. I had the battery bay half filled with water.. Had no water at the pollen filter, but it was close....
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,417
    Audi and VW as the passat suffers the same now just remove the rubber grommets like what they did to mine. There was a revised part but that also suffers and they just take them out now.
    Mike
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Also check the ecu box the seals are also prown for leaking....
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,712
    Quote Originally Posted by lincoln_dj View Post
    Confirm you mean the centre dashboard/windscreen vent and not the centre face vents? (The one that comes on when you press the front windscreen demist button).
    I'd check the evaporator drain is clear, if thats blocked then air will enter the HVAC system.
    Greeny233's Avatar
    Mar 2011
    Leuchars
    550
    Follow Greeny233 On Twitter
    get yourself a dehumidifier once you have drained the plenum chamber around the battery and checked for leeks. A friend of mine who is an auto electrician uses one for cars which have been letting water in and causing electrical faults. It'll stop the misting up and you'll be surprised how much moisture it collects.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    Lancaster
    1,637
    Mines the same, but no blocked drains, no water in the car at all, hvac drain clear all good.
    To do: None yet.
    Jan 2011
    661
    Check flaps on aircon system under the dash to see if the centre vent flaps are in the wrong place and google search audi a4 plenum chamber for grommets issue . Cost me a new brake cylinders on my last A4 that issue,
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    Mar 2012
    160
    Mine is worse then this! My full screen was covered and yesterday morning it had frozen on the inside. I had to do the dreaded thing of wiping it! :/. My pollen filter has been changed a week ago. And my plenum chamber is dry. And ideas?
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    It's that time of year again, come out from work and windscreen and passenger side windows all misted up
    *WANTED* AUDI CD PLAYER
    Oct 2013
    East Sussex
    214
    Same here, I'll be checking the points mentioned above. I had it very bad on the inside yesterday after work and would not bloody clear so I had to wipe it but a prompt visit to tesco for some screen wipes. I thought it was because I fitted wind deflectors on Sunday.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,417
    An old pollen filter is the main cause of this.
    Mike
    Oct 2013
    East Sussex
    214
    How do you get to it?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,417
    It's near the battery
    Mike
  1. Water collecting under windscreen
    By chrisn900 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th June 2010, 13:36
  2. Condensation inside 2007 S3 Headlights
    By prt57 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st March 2010, 19:47
  3. Audi A3 wet floor and inside windscreen
    By E4 FENN in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2009, 11:23
  4. Condensation inside my a3
    By mattm in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2008, 14:59
  5. best way of cleaning inside windscreen?
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th April 2007, 01:30
