AH FabricationsChris Nott
Results 1 to 17 of 17
    pauldazzle's Avatar
    Cardiff
    621
    Changing AC compressor pulley
    Can anyone give me a run down on replacing the AC pulley. Mine has been clattering more & more so I've ordered a new pulley today.
    I'll get my trusted mechanics to do the job, but would like to give them a heads up on any likely problems.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Oct 2009
    Hull
    1,437
    havent the foggiest but what was the cost of the pulley?
    pauldazzle's Avatar
    Cardiff
    621
    Pulley cost £80 inc p&p from Autoklima24 on German eBay, which is £60 cheaper than TPS quoted me.
    Oct 2009
    Hull
    1,437
    bloody hell
    I might just turn the radio up instead!!
    pauldazzle's Avatar
    Cardiff
    621
    If the pulley fails completely turning the radio up isn't going to help the situation.
    Oct 2009
    Hull
    1,437
    calm down I was having a laugh!!
    pauldazzle's Avatar
    Cardiff
    621
    Quote Originally Posted by stu_m View Post
    Me too.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Search leaky Lloyd made a write up I'm sure on a thread about this...
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Jul 2011
    mids
    1,193
    AIR CON PULLEY ISSUE
    there you go take a look
    A4 TDI 130 SPORT..
    pauldazzle's Avatar
    Cardiff
    621
    Thanks Mark, I had actually contributed to that thread, but it doesn't really go into any detail on replacement. Will stick it in to get the job done next week, & write a guide as it seems quite common. I've run for nearly 14000 miles with it rattling, it only used to rattle when climate was on econ but its now doing it when the AC is on too so it's time to sort it before it fails.
    Jul 2011
    mids
    1,193
    I don't think there that bad when you tackle it Paul....
    A4 TDI 130 SPORT..
    pauldazzle's Avatar
    Cardiff
    621
    I'm hoping that with the car up on a 2 post ramp we'll be able to get the compressor off without having to take the front bumper off.
    Jan 2011
    678
    Just had my compressor replaced due to actual compressor failure, pretty sure it's a bumper service position job.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    pauldazzle's Avatar
    Cardiff
    621
    Yes I'm sure that's the case with the V6 engines, but not sure the same goes for the 1.9 PD engines.
    Oct 2009
    Hull
    1,437
    I think you could remove the compressor from the mount and do it you can only try first
    Lancaster
    1,778
    If it's the same as the Audi A6. Easy job bud. My tensioner was broken, so I couldn't adjust it.
    Under try off, you can then get to the compressor. I had to undo the bolts and just release it from the belt that way. You can put it back on this way too. Worked fine. It will then lower down just enough to work on it, use an axle stand to support it. If it's the same, it's a 10mm bolt in the middle. Then you need to pry off the metal cup over the inner pulley. Once that's off, you need circlip pliers to remove the circlip holding the inner pulley. Once that's off, pull off the pulley. Push on the new one, circlip on, outer pulley may need some lube to go back over the rubber. Put some good loctite on the 10mm screw (mine actually came out and the pulley disapeered completely!).
    Put the compressor back on, refit undertray. Took me about half an hour.
    To do: None yet.
    pauldazzle's Avatar
    Cardiff
    621
    Thanks BlackQuat.
  1. Changing aux belt tensioner alternator pulley
    By choimaloy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th June 2012, 23:09
  2. Cambelt Change:Reset Pulleys?
    By StuG808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st April 2012, 23:01
  3. Air compressor pulley mechanism
    By Von Maximo in forum Parts Requests
    Last Post: 8th February 2011, 14:00
  4. changing the gearbox oil
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2003, 06:14
  5. Early oil change on a new Diesel
    By DMitch in forum Diesel forum
    Last Post: 19th February 2003, 17:58
