Sky InsuranceVolks Autos
Results 1 to 10 of 10
    Sep 2009
    Rumburgh Suffolk
    188
    Strange noise at startup..
    Started up Monday morning and there was a noise sounding like a bearing rattling or something connected with the drive belts. I'm sure that it started when I turned on the rear demist, and stopped about a minute later and been quiet ever since.
    I've read things about a clutch on the alternator pulley, any ideas if this is a common thing and if it can easily be checked before it eats itself halfway to work....??
    When I get a chance I'll have a closer look at the weekend..
    If there is a clutch on the alternator, what is its purpose, can't say as I've come across one before??
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    Oct 2009
    Hull
    1,440
    the air con compressor pulley can rattle when its starting to wear
    Sep 2009
    Rumburgh Suffolk
    188
    I'll try and get it to do it again when I get a chance, I'll check the aircon pulley too... even stranger the Landy done it too on Saturday for a few seconds...
    Mark
    Oct 2009
    Hull
    1,440
    try hitting the econ button the air con pulley should rattle if its that
    Landy? is it an old one?
    Sep 2009
    Rumburgh Suffolk
    188
    Quote Originally Posted by stu_m View Post
    No, 2004 mate, keep thinking about an old one thought, V8.....
    Mark
    Oct 2012
    429
    It could be the alternator pulley, i have just done mineeventually they seize adn when you are on full lock trying to park for example they make quite a racket, a chirrup noise on start up is also common when they are failing. New ones from audi depending on model of alternator range from 60 to 90 quid, GSF do them for £30.00 odd, you will need a special tool to undo them as well, be careful that you know whether it's spline or torx on the alternator shaft. Mine was so seized on the shaft i ended up having to angle grind it off!!! Even with the special tool.
    I do have a new pulley as in the end replaced the whole alternator, but thats another story!!
    Oct 2012
    429
    Sorry forgot to say it will also eventually shag the ribbed belt tensioner, as i thought mine was toast did that first, wasted my money!!
    Oct 2009
    Hull
    1,440
    you can check the alternator clutch with a this screw driver if it moves its fine
    Quote Originally Posted by demus View Post
    I have a 1972 series 2A lightweight that could be up for sale but its not something you would want to put a V8 in its worth a pretty penny!!
    Sep 2009
    Rumburgh Suffolk
    188
    I'm guessing when you say check with a screwdriver that its a one way clutch and internals will turn if the belts are still??
    What is the purpose of the said clutch out of interest?? edit that.... just done some reading and it all makes sense now..
    Sounds like a nice Landy, LandyZone - Land Rover Forum is a good site, some good people on there....
    Mark
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Could also be the Duel mass flywheel.
    Mine rattles on start up some times or if my revs dip to low when pulling away.
  1. Strange Noise when reversing
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2009, 18:40
  2. Strange Noise - Sounds like BOV
    By godwine in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2004, 22:52
  3. Noise on startup Audi S3
    By RichWalk in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2003, 11:07
  4. Strange noise..
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2003, 00:44
  5. Strange noise - anybody got a clue !?
    By audi_girl in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:52
