Badger5AH Fabrications
    Sep 2010
    Starter Motor removal 1.9 tdi manual
    Hello all.
    Been a member on here for a while and read a lot of stuff be never really posted till now.
    Basically the car wont start, there is a click as the solenoid engages but no power being taken from the battery, battery is fine so my think was mabe a lose connection to the starter motor. Unfortunately this doesn’t look to be the case so Im planning on taking the starter motor out. The car is a 1.9tdi manual, my Haynes states a fairly simple removal process. However after reading some forum stuff it looks like the front clip has to be pulled forward into the service position to gain access. Is this true, also if it maters it has a/c so the compressor for that is also clogging up the area.
    Cheers Scott
    simon.m's Avatar
    Oct 2009
    2,746
    i did mine about 2 years back and i just took it out did not even bother to look into if i had to put any thing into service position or not lol just disconnected the battery and undid the 3 bolts on the starter motor and pulled it out no probs at all. mine is a 52 plate tdi
    Oct 2009
    Hull
    1,437
    Re: Starter Motor removal 1.9 tdi manual
    As above really easy to do can be a pain to wiggle out if you don't do it right
    Sep 2010
    thanks boys, for any one reading this in the future. as above really very simple if a little mucky,
    undo two bolts from behind the crossmember holding the starter in plac.
    maneuver the motor around to gain access to remove the wires from in front of the cross member .
    then maneuver final to remove from behind crossmember.
    Yet to reinstall but in true Haynes style. Do the above in revers!! O and take the battery off.
    Thanks again
    Scott
  1. audi a3 2.0 tdi 140 starter motor location?
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2011, 10:43
  2. tdi starter motor
    By tara_nta in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2011, 12:26
  3. starter motor on a 2.5 TDI ?
    By Turkster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th September 2010, 17:52
  4. Changing Starter motor on a3 2.o tdi
    By m.lemon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2010, 13:41
  5. A3 1.8T Starter-Motor removal ??
    By jiffi77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2006, 21:40
