Volks AutosSky Insurance
Results 1 to 8 of 8
    May 2012
    10
    A4 B6 1.9TDI - boost/starting issues - only in the rain???
    Hi,
    has anybody come accross a similar problem like this. Earlier in the year I had the EGR valve replaced as car would stall and not restart on a wet day.
    Car has run fine for 3 months. Today (raining) really poor accelaration then suddenly kicks in lurching forward.
    I am assuming the issue is still rain related
    Any thoughts welcome
    Tim
    Aug 2012
    Medway, Kent
    162
    On a side note, how much did it cost to replace the EGR valve and out of interest why did you replace it and not just block it off or get a delete kit?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,569
    You must have a short somewhere.......and the rain must be arcing something
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    May 2012
    10
    It was about £250 from memory. To be honest I hadnt had the car long and didnt know about the other options, garage didnt mention it either. Is it a common problem with the EGR valves on the b6?
    Drove it again tonight without fault, obviously an intermittant issue.
    Aug 2012
    Medway, Kent
    162
    Quote Originally Posted by Tim Woodman View Post
    All EGR valves go wrong, doesn't matter on make of car unfortunately it just doesn't work for very long lol.
    May 2012
    10
    any ideas where that short could be? Whole thing lacks power, I'm having to rev it like mad to get going then suddenly find your self flying off down the road. Not the safest way to drive!
    May 2012
    10
    thanks i'll investigate the kit if it doesnt get any better. I assume it doesnt do any harm to bypass it?
    Aug 2012
    Medway, Kent
    162
    Should make it better, more responsive etc Blocking it off is the easiest way - or if you want it removed all together then get the EGR delete kit - Allard 1.9 TDI EGR Delete kit for VW Golf Mk 4 GT Tdi 130 + 150 | eBay
  1. 1.9tdi - boost issue
    By twist123 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th July 2012, 13:08
  2. Replies: 23
    Last Post: 30th July 2011, 10:47
  3. Cold Start Issue......?
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2007, 14:48
  4. Cold start issues? Maybe it;s your O2 sensor.
    By eddyg in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2006, 02:03
  5. 1.8 SE intermittent starting issue
    By easytease in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd February 2006, 09:42
