Sky InsuranceVolks Autos
Results 1 to 21 of 21
    glenandem's Avatar
    Sep 2012
    manchester
    528
    cheap egr delete kit on ebay
    would this fit my awx 130 1.9 tdi a4,it says its for the 130 pd engines as well as others and anyone know if theyre any good as most people i read go for the allard kit?
    DEEPZONE Stainless EGR Delete Kit VW Audi 1.9 TDI PD130 PD150 | eBay
    Nov 2011
    South Lanarkshire
    81
    I have been looking at these as well. I would say it would fit the audi.By the looks of it you would just need to cut the metal end from your turbo pipe to make it fit. Also it's way more cheaper than the allard version.
    M
    Oct 2012
    Warrington, North West
    986
    What are the benefits to fitting these? Thinking about one for my 2.0tdi
    glenandem's Avatar
    Sep 2012
    manchester
    528
    Quote Originally Posted by Mikemc View Post
    Improved emissions better mpg no stutter from dicky egr tiny performance gains but you'd hardly feel it really!
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Guys,
    you don't need any fancy kit like this. You need to just buy a blank, about £3, and then have it mapped out.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Oct 2009
    Hull
    1,440
    Re: cheap egr delete kit on ebay
    Even cheaper if you make a blank plate and on early models you don't have to have it mapped out
    glenandem's Avatar
    Sep 2012
    manchester
    528
    Quote Originally Posted by Rick @ Unicorn Motor Dev. View Post
    Guys,
    Rick
    i thought about doing that as i made a few plates for other motors and a few transits i had a while back but ive read things about the butterfly bit braking off in the audi's and being sucked right into engine,not sure how true it is but i thought for £37 is it not worth just throwing it on?
    Oct 2009
    Hull
    1,440
    first I have heard about the butterfly coming off on the B6!!
    glenandem's Avatar
    Sep 2012
    manchester
    528
    yeah i seem to recall reading on an audi forum somewhere and thats what made me think about just swapping the whole lot out rather than put a blanking plate on?
    maybe it was just a one off as ive not read many more issues of it but where i read about doing away with egr's on the audi's there seems to be alot more people buying these kits than throwing a blanking plate on for some reason?
    Oct 2009
    Hull
    1,440
    you may have read about swirl flaps breaking off on newer ones as thats been known to happen
    glenandem's Avatar
    Sep 2012
    manchester
    528
    yeah could have been pal,i just thought thats why most people replace the whole lot rather than put a plate on!
    think i'll just make a plate up then and put that on, you saved me £37 squids now pal lol!
    Oct 2009
    Hull
    1,440
    thats all i did was make a plate and plugged the end of the vac pipe on the egr
    some people have just plugged the vac pipe to stop the egr opening
    BRILLO's Avatar
    Sep 2011
    Juniper Green, Edinburgh, United Kingdom, United Kingdom
    137
    i plugged the egr vac pipe on my 2.5tdi and it made it spin up a bit quicker then i eventually made a plate.. Never had any probs and much less smoke..
    glenandem's Avatar
    Sep 2012
    manchester
    528
    ive seen people selling two plates on ebay,one for each end and one guy goes on to suggest that you should block both ends due to oil vapor build up etc in the pipe if you only block one end up?
    heres his quote-
    "I recommend blanking of the opening in front of the EGR valve. It is not recommended to cap only at the outlet manifold in engines of the VAG consortium. It may cause filling of the tube connecting the outlet manifold with the EGR valve with a slurry of water and oil (the EGR valve shall still work and during opening cause penetration of oil particulates from the crankcase breather tube)."
    Oct 2009
    Hull
    1,440
    its ****** mine has been blanked at one end for 2 years and came apart the other month and hardly had any oil in it
    glenandem's Avatar
    Sep 2012
    manchester
    528
    thought as much lol!
    Aug 2012
    Darlington
    172
    My 130 is blanked with just a cheapo plate off ebay and the hose plugged up. Has ran sweet as a nut for the last 10k, no noticeable downsides
    glenandem's Avatar
    Sep 2012
    manchester
    528
    i just recieved a plate off ebay today,quite thick actually!
    did you just slide yours between the pipe and manifold and did it go in ok being so thick!! ooh err
    Feb 2012
    Teesside
    15
    Hi Brillo, I have just been informmed about blanking off the EGR but do not know where it is or how to go about it.
    I also have a 2.5tdi Avant on an 06 plate. Could you help describe where to find this EGR valve and how/what you made the plate out of.
    Any advice would be greatly appreciated.
    Thanks.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    628
    Quote Originally Posted by stu_m View Post
    hi rick
    I notice u say this a couple of times,can you tell me of any differences if its mapped out or not?
    Ive blanked mine but put the light on. I assume if its mapped out the light wont come on.
    Anythink else to note with a mapped out egr compared to just blanking.
    Cheers.
    Jan 2012
    Stockport, Cheshire
    748
    It needs to be mapped out to work, plain and simple. If not, you will be constantly in limp mode, and the ECU will be expecting airflow through the EGR which it's no longer getting.
    Thanks, Rick
  1. Hi all is this the right EGR delete kit?????
    By holmefield in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th March 2014, 21:16
  2. Allard EGR Delete kit?
    By sinic in forum Diesel forum
    Last Post: 18th April 2012, 13:37
  3. Allard 'Powerpipe' EGR delete kit Vs EGR blanking plates?
    By BudgieV8 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2011, 19:52
  4. EGR Delete kit problem - 19TDI ASZ
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2011, 20:21
  5. Allard EGR delete kit
    By TDiSPORTA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th June 2010, 21:55
