Volks AutosChris Nott
Results 1 to 8 of 8
    Jun 2012
    Teesside
    448
    Steering Control Module??
    Hi all i done a quick search and theres a fair few threads about the retrofitting cruise control etc, but the specific question im after knowing the answer too, is can i only get the necessary module from an a4? or do the a6's use the same ones?
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    Oct 2009
    Hull
    1,442
    Re: Steering Control Module??
    Go by part number then you know you have the right one you don't have to worry where it comes from
    Although in answer to your question I'm not sure if an a6 will fit
    simon.m's Avatar
    Oct 2009
    2,746
    i no of some one that does it for 110 all in thats parts and fitting let me no if you what the link
    Jun 2012
    Teesside
    448
    Surely that wont include the module simon? they go for 70+ on ebay etc, i believe the one in my car is the model 8E0 953 549 F, which from my research doesnt support cruise, :S this is why im after either a midline or highline so i can have cruise and DIS
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    641
    • Lowline
      • Supported Steering Wheels: Standard Steering Wheel (4-Spoke)
      • Supported Features: Trip Computer (does NOT support Cruise Control!)
      • Part Numbers: 8E0-953-549-F 8E0-953-549-S
    • Midline
      • Supported Steering Wheels: Standard Steering Wheel (4-Spoke), Sport Steering Wheel (3-Spoke), Multi-Function Steering Wheel
      • Supported Features: Trip Computer, Cruise Control
      • Part Numbers: 8E0-953-549-L, 8E0-953-549-N
    • Highline
      • Supported Features: Trip Computer, Cruise Control, Steering Wheel Heating
      • Part Numbers: 8E0-953-549-M, 8E0-953-549-P, 8E0-953-549-Q, 8E0-953-549-R
    Hope this helps you.
    Personally I've got the Highline "Q" variant.
    simon.m's Avatar
    Oct 2009
    2,746
    Quote Originally Posted by Dan TheMan Welburn View Post
    no it does not include the module but if thats needed he then does it all for £190 all in still a good price if you ask me. i have toyed with getting it for mine but i dont no how to check what model i have .
    beachbuggy's Avatar
    Surrey
    1,746
    Quote Originally Posted by simon.m View Post
    If you don't want to take the steering column apart to check part number then you can try coding the the module with vcds, there is one but you need to change to activate cruise , now if you have the F module non cruise fitted when you try and save the new soft coding it won't save where as if you have the L module with cruise then the changes assuming already not active will save.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    scan with vcds to get your part number
  1. Steering Control Module discovery (MFSW)
    By Ash187 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2014, 17:44
  2. Fitting steering control module without steering angle sensor
    By Pricy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th June 2012, 17:21
  3. A4 B6 Steering control module 8E0 953 549 S
    By Mark_Eire in forum For Sale/Wanted - Audi Parts
    Last Post: 10th April 2012, 12:34
  4. Replacing steering control module.
    By Morten88 in forum General Technical / How To
    Last Post: 5th April 2011, 00:02
  5. HELP!!?? Cruise control retrofit steering wheel module part number???
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th June 2009, 11:18
