Sky InsuranceEM Tuning
    Oct 2012
    bedfordshire
    9
    battery light flashed on.
    Hi everyone,
    I was giving my 2.5tdi a clear out yesterday and at around 4200 rpm in (3rd i think) the battery light, lite up for a split second.
    Has anyone else had this? or does anyone know why this would happen?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,566
    Check the battery terminals and also the output of the alternator..........otherwise never had it happen to me
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,266
    Possibly the belt that drives the alternator maybe Slipped
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Check the alternator pulley mine was nearly in 2 pieces lol....
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Jul 2007
    London
    3,235
    Quote Originally Posted by marktdisport View Post
    The v6 tdi has a solid pulley, does not have a one way clutch like the pd engine. I suspect the brushes are worn on your alternator or a diode is on it's way out. I strongly hope that your aux. belt tensioner is in good condition and the bushes are not worn, otherwise it's a front off job to repair. When the bushes wear trough (they are 1mm thick) the aluminium bracket wears very fast and requires a new cast bracket (doubles as PAS and A/C bracket) which is a pain to replace as it requires oil cooler removal- messy and tricky due to lack of room !
    Easy to see if the bracket is worn, when the plastic damping cover/noise insulation is removed the belt running on the aux. tensioner will run close to the edge and cuts into the plastic/melting it ! TPS keeps parts in stock as it's a common failure...
    FOR SALE:
  1. Battery Light Flashes when heavy throttle used
    By rojocho in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th June 2012, 20:11
  2. Flashing battery light...
    By AudiS3-Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2012, 22:25
  3. Need help!! Battery light flashing
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2012, 19:57
  4. Battery light flashing on display
    By solihul in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2006, 12:09
  5. alarm light flashing
    By stebed in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th March 2005, 22:05
