Chris NottMonster Motorsport
Results 1 to 10 of 10
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Converting front fog lights to drl's BULBS NOW FITTED
    Is this legal to do, the wiring is simple to make these come on when ignition is on and go off when headlights are switched on (if wanted).
    When my wife gets home she's bringing my LED H11 bulbs i bought off ebay (got delivered but no one in to sign for them so had to be collect from sorting office) I'll get them fitted straight away to see how bright they are and take some pics.
    Here's the bulb i bought:
    H11 XENON WHITE HIGH POWER 7.5W CANBUS LED CAR FOG LIGHT LED BULBS (pair) | eBay
    Has anyone else fitted LED fog bulbs?
    Jan 2012
    1,837
    You can change DRL behaviour with vcds - change it to Canada if you have access to it and the fogs will be running all the time.
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Quote Originally Posted by A6CR View Post
    Will i need VAG com to do this?
    Oct 2012
    Stanley, County Durham
    151
    So is it legal to change normal fogs to these xenon LEDs? Would these work on an 03 cabriolet, just plug in to replace the old normal bulb, or more work required?
    i'm guessing that as it isn't mandatory to have front fogs, you'd be ok? Plus, if they're not normal fog lights, the fuzz wouldn't stop you using them?
    Jan 2012
    1,837
    Fogs aren't legal to use if its not foggy.
    Try explaining your fogs are actually DRL to plod. It won't go down well.
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Quote Originally Posted by pbarlow0032 View Post
    That's what i thought as the Volvo's use the same fog light style round DRL's
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Bulbs now fitted.
    A few pics:
    one fitted not as much glare as the standard fog so thats a good thing:
    both fitted, on with just side lights:
    With HID's on too:
    I'll take some daylight pics tomorrow.
    Oct 2012
    Wigan
    178
    Looks great that
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Are you sure about this on B6's? I've never heard of it before.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,538
    Apparently 2002 models you can have fogs as drls otherwise you have to mod the light switch to change side lights to fogs......simple wire cut and bridge op.
    Tried the drl mod with vag com on my 2004 and it works but without light switch mod only my sidelights act as drl. They are always on when key is turned in the ignition.
    Just changed my fog light bulbs to LEDs also and want to look further into doing the light switch mod.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
  1. front fog light
    By a4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2006, 16:44
  2. Front fog lights for a3 1.8t 2000
    By tick in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2005, 11:08
  3. Newbie - Front fog lights
    By surren20 in forum Volkswagen and other VAG
    Last Post: 11th November 2004, 20:18
  4. S3 front fog light
    By imported_maviceuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2004, 20:59
