AH FabricationsJMB Retrofits
Results 1 to 8 of 8
Thread: Gearbox issues
    Jun 2011
    130
    Gearbox issues
    Hi all
    My tiptronic auto box is playing up,seems to have hesitation,and sort of banging into gear when slowing down, also when slowing down the rpms fluctuate and drop, when gas applied seems ok, its just not right
    any ideas ??
    audi a4 3.0 quattro
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    i never have and never will have the tip in a audi.
    Jun 2011
    130
    Thanks for the helpful wisdom !!!!
    bez101's Avatar
    Jul 2008
    8,492
    your welcome.
    did you try the search function theres loads on that box.
    Jun 2011
    130
    Could this be a simple case of a blocked or dirty fuel filter ??
    Jul 2007
    770
    The tiptronic is said to be reliable.Mines never been any trouble.If it was the fuel filter wouldnt that affect the running under power.I would get a diagnostic check done
    Oct 2012
    429
    VCDS/Vagcom the car first it might be a controller issue, if not then it's mechanical inside the box
    Jun 2011
    130
    Done a scan, no fault codes !
  1. Does the A3 have gearbox issue's or any other ?
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th December 2008, 15:11
  2. Automatic gearbox issue
    By pmdk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st June 2008, 15:20
  3. S4 Gearbox issue......
    By nemo2182 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2007, 14:21
  4. Please diagnose this clutch/gearbox issue
    By Aky in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2007, 23:10
  5. ping Scotty - gearbox issues???
    By imported_Teutonic_Tamer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th August 2004, 13:52
