Chris NottEM Tuning
Thread: Winter Tyres
    Nov 2012
    Germany
    Winter Tyres
    I currently have 235/45/R17 on my Audi. I have been offered 235/65/R17 winter tyres, Will these fit on the alloys (standard A4 alloys).
    Very good price I hope they do
    Nov 2012
    Germany
    Im sure the 45/65 Difference is just the Depth of the tyre. the 235/R17 is width and Size. I need a quick answer on this before they go. is the 45/65 a massive difference and will they fit
    SLineMK's Avatar
    Nov 2012
    45
    Winter Tyres
    Don't think the extra 20mm on the side wall will make much difference, ride height adjustment, speedo out I'm assuming your car is not lowered and the extra will fit under the arch
    Oct 2009
    Hull
    1,434
    Quote Originally Posted by robster2644 View Post
    No its not its and aspect ratio of the height of the side wall the 45 and 65 is a percentage of the 235 giving the height of the sidewall
    they will fit on the rims but stand a little taller dont think it will be enough to cause an issue though
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    278
    the tyres will probably rub, the 45-65 profile means a 20% in overall difference. Your speedo will read 70, you will really be going at 84mph.
    I would get correct size
    kevbu's Avatar
    Aug 2010
    55
    I think too big. Probably off of a 4wd like an X5 or similar. Dont think they would even fit in arches, near enough 6" bigger in dia.
    As been said the 45 and 65 are the % aspect ratio of the 235mm width.
    Would look a bit MadMax if they went on though.
    Specification -Sidewall- Radius - Diameter -Circumference- Revs/km- Difference
    235/45-17 -106mm -322mm -643mm- 2021mm -495- 0.0%
    235/65-17 - 153mm - 369mm - 737mm- 2316mm -432- 14.6%
  1. Winter Tyres; Summer Tyres. Should I bother and why?
    By The Maestro in forum General Automotive Chat
    Last Post: 26th April 2010, 22:40
  2. Winter Tyres & Wheels
    By stevehall in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th January 2010, 14:24
  3. Winter Tyres
    By lewis in forum General Chat
    Last Post: 4th December 2008, 21:47
  4. winter tyres
    By tracer in forum Handling
    Last Post: 10th November 2006, 16:09
  5. Winter Tyres
    By howatsi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th October 2005, 13:54
