Results 1 to 23 of 23
    glenandem's Avatar
    Sep 2012
    manchester
    459
    painting rs4 alloys
    hi ive just bought a set of 19 inch b7 rs4's that im gonna paint a dark grey colour and have already started prepping them but for anyone who's done this before can i ask,do i need to reprime the alloys or will the scratched up flatted old paint be good enough for paint to go over and can i use normal car bodywork paint rather than just the wheel paints you can get as i want different colour to the silvers they come in and finally has anyone used the halfords laquers before and if so are they any good?
    Jun 2010
    East Manchester In the Hills !
    597
    painting rs4 alloys
    Always prime before paint.
    I have used normal halfrauds paint and lacquer and they came up a treat.
    I have also used some coarse flake silver from auto paints and they looked ace.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Complete of layers of primer m8 this will help the paint stick better to the alloys ready for some lacquer
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    glenandem's Avatar
    Sep 2012
    manchester
    459
    Quote Originally Posted by marktdisport View Post
    Hi guys better get some primer then, just thought the original paint would be ok for a base once I'd sanded it back abit!
    Suppose more primer isn't a bad thing, will help fill the tiny little marks in!
    I'll get some pics up when done, dying to throw thrm on the car now
    Jul 2012
    Derbyshire
    306
    Don't rush it that's the key prime then paint then makes sure there properly dry before lacquer should look good
    Jun 2010
    597
    painting rs4 alloys
    Here's on I did earlier
    Take your time. It's all in the prep
    Jun 2010
    597
    painting rs4 alloys
    All with halfrauds paint, lacquer and high build primer
    Cost me about £50 quid to do all 4
    glenandem's Avatar
    Sep 2012
    manchester
    459
    Look well them pal, yeah I'm taking my time sanding thrm down, I've been using a load of the scotchbrite style pads at the mo to get in the spokes etc but all coming out nice, should I get the etch primer or just normal grey stuff?
    Jun 2010
    597
    painting rs4 alloys
    I used the yellow high build primer. It filled a lot of the imperfections without having to fill and sand everywhere.
    It just takes a few more coats of colour to cover it.
    The grey primer is easier to cover if your going silver on top.
    Lacquer run like hell so lots of thin coats of this.
    Jul 2011
    mids
    1,193
    Quote Originally Posted by lgooch View Post
    +2 for high build primer will help hide the rough parts
    A4 TDI 130 SPORT..
    Mar 2012
    160
    like above really, the halfords lacquer runs like hell if you go mad or overspray to much. many thin coats is best.
    dont forget to flat back for best results!!
    gavsman's Avatar
    Sep 2011
    379
    Don't forget to pop the can's ( colour & lacquer) in hot water ( not boiling hot!) for a min before spraying, so the paint doesn't spit when you apply it.
    mookie's Avatar
    Oct 2012
    Newcastle Upon Tyne
    43
    I always do my own wheels, never spend much and always get good results. Be thorough and careful, it's worth more than paint and gear.
    I do it this way:
    1. good rub down, really dull the old paint.
    2. if any alloy/bare metal is now exposed then etch primer is vital. Or at the very least some red oxide (has more bite than grey)
    3. high build primer to fill out nicks or marks
    4. another rub down with medium paper
    5. primer, couple of light coats building up
    6. rub down any runs or belmishes
    7. apply the colour. lots and lots of thin coats, but put too little on and it will rub off later or rub through when you wet sand
    8. lightly wet sand when completely dry, dull down the colour and take off any gloss to the finish
    9. lacquer it. lots and lots of coats. usually recommend two or three, on wheels I do as many as the can gives me to be sure.
    10. wet sand again to get it smooth as glass and shiney.
    But then don't do what I did with my old TT Comps, and lean on against a wall while fitting to the car after paint... little puff of wind and it fell face down on the concrete drive
    Couple of my old sets
    BBS RMs splits
    Compare! by mookboy, on Flickr
    Azev A's in VW Sand colour
    photo by mookboy, on Flickr
    IMG_0937 by mookboy, on Flickr
    Satin finish on these TT comps
    IMG_1782 by mookboy, on Flickr
    IMG_1784 by mookboy, on Flickr
    BBS RA's done just using tradespray wheel silver
    Close up of paint by mookboy, on Flickr
    Jul 2011
    mids
    1,193
    Love these TT wheels
    A4 TDI 130 SPORT..
    glenandem's Avatar
    Sep 2012
    manchester
    459
    hi guys,did them last night while the wife took the kids to the farm round the back of the house for fireworks!
    was well pissed off missing bonfire night lol, anyway i'd sanded them back other the weekend and filled the scrapes in and primered,so last night just gave the primer a quick flat and sorted out any obvious marks,i wasnt after a perfect finish as i know the wife will probably curb them soon, i gave them about 3 thick coats within half an hour of each other with halfords own anthracite alloy wheel paint and i have to say it went on well and didnt run and even had a nice shine to it before i put lacquer on, i then did the lacquer and as people have said halfords stuff is very runny so was very carefull however one wheel had a few runs so i waited an hour for it to dryish and flatted it back and redid it and it came good.
    left to dry in the kitchen all night and stinking the house out and this morning took masking off and tyre blacked and new shiny valve caps and they look really nice, will put pics up in a min!
    just not sure whether to throw them on the car tonight or give them anouther 24 hours but they feel really dry and hard already?
    Jul 2012
    Derbyshire
    306
    They look great pal get em on
    mookie's Avatar
    Oct 2012
    Newcastle Upon Tyne
    43
    They look really nice! Congrats!
    munchkincoupe's Avatar
    Aug 2010
    971
    Good job there
    I always use ProXL 2k Clear lacquer - excellent quality, hard finish, builds up well, drys faster and less prone to running like the Halfords stuff
    Car Paint from AutoPaint St Helens - 500ML PROXL LACQUER (Powered by CubeCart)
    Jul 2011
    mids
    1,193
    Sweeeeeeet
    A4 TDI 130 SPORT..
    mookie's Avatar
    Oct 2012
    Newcastle Upon Tyne
    43
    I always just put the can of lacquer on the radiator with the heating on, for a good hour. Nice and warm and comes out fine and not dribbly or in splattery (as Halfords stuff tends to do).
    glenandem's Avatar
    Sep 2012
    manchester
    459
    quick pic in the dark!
    drives really nice but needs lowering now!
    old 17's sport alloys up for sale £150 if anyones interested?
    mookie's Avatar
    Oct 2012
    Newcastle Upon Tyne
    43
    I really like that combo mate, just the sort of thing I want for my SE.
    Jun 2010
    597
    painting rs4 alloys
    Let the, dry for a few days and really harden
  1. RS4 alloys paint match
    By martyboy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2009, 20:15
  2. 18" RS4 Alloys
    By ScottyKemp in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2004, 15:51
  3. RS4 Alloys on S3 Pictures/Advise Please
    By Parf7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2003, 19:51
  4. Audi A6 with 18'' RS4 Alloys
    By daniel in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th August 2003, 23:13
