JMB RetrofitsChris Nott
    deanski's Avatar
    wax on, wax off
    May 2010
    Lancashire
    374
    Couple of issues with the B6
    Hi all,
    has anyone changed a brake pad warning sensor and are they hard work? Mine has snapped off from the caliper end, probably a pot hole.
    Also, I can hear a clonking noise when coming off the accelerator but nothing under braking. Was thinking engine mount but open to other suggestions.
    thanks
    Dean.
    A4 B6 1.9 tdi 130. Slowly modding but don't tell the missus.
    Front ambient lighting
    Eibach sportlines.
    Audi TT Alloys.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    the warning sensor is the brake pad
    has the wire snapped ?
    the clonking could be a number of things
    like top arms the c shaped link ball joint etc.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,152
    Brake pad sensors are really easy - I don't think you can actually buy the sensor as such, as they come fitted to the brake pads.
    You can however cut the wire and solder together.
    The way the sensors work is that when the pad gets low, they wear through the wire, which brakes the circuit and throws the dash light.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    deanski's Avatar
    wax on, wax off
    May 2010
    Lancashire
    374
    yeah the wire has snapped from the back of the caliper.
    Eibach sportlines.
    Audi TT Alloys.
    bez101's Avatar
    Jul 2008
    8,492
    either replace pads
    wire it back togeather
    or bypass it till your ready for new pads.
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    Has it ripped from the car side of things or from the actual pads?
  1. An up and down couple of weeks with the B7
    By mike beech in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th August 2009, 11:40
  2. Help! - Issue with the red devil...
    By BLP in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd March 2009, 20:27
  3. Couple of issues with my S3
    By cooni in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th February 2008, 22:05
  4. Common Issue with the DIS
    By coupe-se in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th February 2007, 19:19
  5. Just made a couple of vids with the DV moved.
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th April 2005, 11:00
