AH FabricationsBadger5
Results 1 to 12 of 12
    Oct 2005
    yorkshire
    112
    Traction light and glow plug light flashing??
    Hi all, got a problem with my b6 - basically on full lock to the right and when driven forward I noticed sometimes that there is rumble,
    Only does it sometimes, today it did it on full lock and the traction control light has come on - switched the car off and now traction light is on and the glow plug light has started flashing?
    Any ideas what this can be?
    Car drives fine, brakes are fine, brake lights are ok also...
    Please advice.
    2004 A4 1.9 TDi Sport Avant Quattro - HiD's - FULL RECARO LEATHER - S4 Mirrors - Cupra R Splitter - Heko Wind Deflectors
    Oct 2005
    yorkshire
    112
    Forgot to mention this is not on my Quattro, it's on a normal b6!
    Oct 2012
    77
    Hey I'm new to the forum. Glow plug symbol's flashing on my 2003 A3 and it's giving the fault code 16955, I think my brake light switch is at fault so I'm going to replace it. They're cheap to buy and pretty easy to change though haven't got round to doing it yet. My brake lights still work so assuming the switch is on the way out and not knackered yet.
    Oct 2005
    yorkshire
    112
    I had this once on my bora but the brake lights weren't working - changed the switch all was fine!
    But now my lights are working and everything seems to work also
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    It all points towards the brake light switch, ideally you want to get it scanned, but if you can't I'd change that first off.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Mine done this before I sold it and noticed my brake lights had failed
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Oct 2012
    Wigan
    178
    yep i changed replaced the duf bulb and was fine after this
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Shaz did you fix this problem?
    I see from other posts that this could be from the grommets being blocked and water running down into the car
    Mine started with this problem tonight and no rain so im hoping its the brake light switch or a bulb out, not an ECU problem
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    Jul 2011
    mids
    1,193
    Quote Originally Posted by scottshere View Post
    Most definatatly brake switch bud cheap fix when it happens try and catch your brake lights in the mirror
    A4 TDI 130 SPORT..
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Quote Originally Posted by marktdisport View Post
    Thanks, i just checked today and my brake lights arnt working, the one in the rear window is though... This makes me wonder
    Mate at work says he noticed i had a bulb out last week, so will check them all tomorrow and see if changing the faulty one works
    If not then off to the stealers for a switch...
    Oct 2005
    yorkshire
    112
    Hi mate, sorry for late reply, yes it was the brake switch, bought it from GSF and fitted myself,
    Thanks to all the guys on here for the advice
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Same here.... Fixed mine too yesterday
    Turns out it was a blown bulb !!! Easy fix
  1. Uh..oh... Flashing glow plug light and limp mode :(
    By dubdemand in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3 Weeks Ago, 17:03
  2. Flashing glow plug light and no accellerator!!
    By blucoop in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2013, 11:51
  3. ESP Light on and Glow Plug Light Flashing - Car Cuts Out! Help!
    By jay786 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th June 2012, 18:39
  4. Replies: 2
    Last Post: 25th November 2010, 16:00
  5. flashing glow plug light and wouldnt run
    By flyingfisherman in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2009, 16:08
