Chris NottAH Fabrications
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    headlight alignment check
    just about to upgrade my bulbs in the headlights.
    ive heard you have to get the alignment checked afterwards, my question is can this be done by using vagcom, and how
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    MOT test centre.....some dont charge others may charge about £10
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Whenever I swap my bulbs, I park on the level about 6ft away from a wall, garage door etc. Turn the lights on and mark the beam pattern on the wall with tape or chalk, and then when you put the lights back in set them to that. The alignment is an internal mechanism inside the light, you won't touch that. You just need to mount the lights back in the same place.
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    I do the same as James
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
  1. Headlight Alignment
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th October 2008, 19:28
  2. S3 Headlight alignment/levelling
    By pablo in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2006, 23:14
  3. Failed MOT with a Xenon headlight alignment issue
    By chief_b in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2006, 18:40
  4. Headlight Alignment
    By tonedef in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2006, 13:13
  5. facelift headlight alignment
    By ultramodz in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2005, 23:44
