Sky InsuranceEM Tuning
    Oct 2012
    East Kilbride
    286
    gear selection on startup
    Hi all...
    just noticed that from cold it's really hard to select first or second gear... it's ok once the car warms up though...
    is this just a quirk of the manual box, or is there a problem looming!?!?
    it's about to get an oil change on the box and diff....
    cheers
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    Mine was the same - especially during the colder months.
    I replaced the gearbox oil a few months ago - I used the Fuchs oil recommended from Opie Oils.
    It was instantly better - I also believe you can reset the gear linkages also - but not sure on how this is done.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,412
    Also when was the last time you did a brake fluid change and also bleed the clutch
    Worked wonders for me when I did the brake fluid change
    Mike
    Oct 2012
    East Kilbride
    286
    cheers... I've just got the car, so I'll add bleeding the clutch to the list...
    the rest have been done or are about to be done...
    :thumb:
  1. Gear selection problem
    By dope in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th December 2008, 15:02
  2. 2003 1.9TDI ( All gear selection lights flashing)
    By 69COU in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th August 2008, 17:04
  3. A3 1.8T 1999 Gear Selection Problem. In need of advice/help
    By shawshankuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2008, 21:21
  4. A3 tdi 1st / 2nd gear selection problem
    By davidelson in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2007, 07:41
  5. A3 Sport Gear Selection
    By Rob Haig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th October 2006, 11:02
