Volks AutosMonster Motorsport
    Bean5's Avatar
    kidney bean
    Jan 2012
    stafford
    334
    Rattly engine when started?!?!
    Hi guys, noticed today for the first 5-10 seconds of starting my car, engine sound a touch rough/rattly/dry... A bloke I work with reckons its the injectors need a clean... What dya think???
    And if it is likely to be this is it just a case of getting some injector cleaner?
    cheers
    Next Steps. (wanted)
    s`line steering wheel
    oem interior mods
    milltek exhaust system..
    window tints.
    Oct 2009
    Hull
    1,433
    what engine?
    could just be the lack of oil around the engine most rattle a little for a few seconds till the hydraulic followers get some oil
    Oct 2012
    Wigan
    178
    could try a thicker oil in it with the weather getting colder
    Bean5's Avatar
    kidney bean
    Jan 2012
    stafford
    334
    1.8t cheers
    oem interior mods
    window tints.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    Quote Originally Posted by Neilb1 View Post
    *thinner.
    This could possibly be due to the oil strainer being slightly clogged and not supplying oil to the top end quick enough.
    The oil strainer clogging is a common issue with the longitudinal 1.8T engine.
    Oct 2012
    Wigan
    178
    Quote Originally Posted by AlexGSi2000 View Post
    *thinner.
    try thin oil for the winter because the cold temperatures will cause the oil to thicken slightly. Likewise, you want thicker oil for the summer because the high temperatures will thin the oil slightly.
  1. engine tappety when starting up from cold
    By Johnny0709 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd June 2012, 22:27
  2. S4 V8 engine rattle when starting only
    By Boomerations in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2009, 22:05
  3. loud blowing noise coming from engine when started up......?
    By rockstar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2007, 17:55
  4. Weird noise when starting engine???
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2005, 11:09
  5. noise when starting
    By JamesA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2004, 08:02
