    VTEC_Killer's Avatar
    Oct 2006
    West Yorkshire
    78
    VAGCOM Error on ABS brakes
    Can anybody help with the following error code from VAGCOM:
    Address 03: ABS Brakes
    Controller: 8E0 614 517
    Component: ABS/ESP front 3429
    Coding: 04255
    Shop #: WSC 06435
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    I've cleared it and it now gone, but I've never had a issue with the brakes so surprised this error has been logged.
    Thanks!
    2004 Audi A4 1.9TDi Sport with GMbH Bodykit
    RNS-E, Parking Sensors, Privacy Glass, Xenons
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,722
    Probably a blip in the controller one cold morning when starting or something, I wouldn't worry if it doesn't return.
    Oct 2009
    Hull
    1,434
    I had this once
    One morning on a very cold day I had the red brake light on the dash at start up which I think caused it as the fault its caused by lack of power to ABS module and the brakes warning is because of a lack of power too!
    I cleared the fault and not been back once
  1. Various ABS / Brake / ECU Error's Does anybody know how to sort ?
    By sc00byd00byd00 in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd October 2010, 14:18
  2. Engine Warning Light 2 VAGCOM Errors 1.8T
    By MingeBlue in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2008, 22:10
  3. Vagcom errors!
    By dickys3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th July 2007, 19:32
  4. help, please decipher vagcom error codes!
    By skanky in forum VCDS (formerly VAG-COM) forum
    Last Post: 12th August 2006, 12:42
  5. 1999 A4 2.4 Avant with ABS, brake pad replacement
    By imported_hornet_basher in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th November 2004, 18:45
