Results 1 to 15 of 15
    A4 S-Line 1.8T Avant 230 BHP
    Oct 2012
    Stourbridge, West Midlands
    38
    Question clunk when turning right hand corners
    Hi all,
    Right my a4 avant is currently in a garage, as when i turn a corner doing 10mph + there is a clunk coming from the front lh side.
    The garage cant find anything wrong at all, anywhere.
    So does anyone have any ideas as its getting stupid now . Thanks
    Oct 2012
    38
    Bump..
    Anyone.....
    Help..
    Please.
    Mar 2008
    1,040
    if it clunks when you turn normaly its a cv joint that has gone
    Oct 2012
    38
    If u turn slow and steady nothing. This is why im guessing its somthing loose.
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    432
    Visit krisavant's Instagram Channel
    Re: clunk when turning right hand corners
    I have this but only on full lock and wet?? Weird.
    Mar 2008
    1,040
    break pads loose??????????
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Sounds more like the front suspension joints.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,257
    there are a few causes of clunks that garages very rarely can find, a lot of people start to change bits willy nilly in the hope if fixes it. The usual and most common ones are from research the lower front and upper rear arm ball joints, track rod ends,drop links,engine mount, gearbox mount, loose pads, antirollbar bushes. You can eliminate the drop links, anti roll bar bushes and pads quite easily with a good look and wiggle etc. My money would be on an arm ball joint although not easy to test, I had this issue last year and i just couldn't tell which it was. it was only when the balljoint was removed from the knuckle after drilling out the dreaded pinch bolt you could tell as you could move it realy easily and others where quite tight still.mine turned out to be top rear, good luck in finding it. i also believe that a cv joint when gone will make a constant clicking noise when driving in a circle on full lock
    Aug 2012
    Medway, Kent
    162
    Someone else had a similar issue on here and it turned out to be the battery that wasn't secured and was sliding around - just something else to check I guess
    Oct 2012
    38
    Thankyou. Im going to have to check brake pads but the braki g is fine etc. It started quiet and its gotten worse. Only problem i have with the car now and its realy bugging me.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,257
    Quote Originally Posted by lanceneoman View Post
    It started quiet and its gotten worse. .
    it always starts like this, I can't see it being the brakes then.
    Jun 2012
    Teesside
    448
    I have a similar issue but when setting off from standing but turning left, i was thinking one of the arms, as my car hasnt had any work on the suspension done in the near 100k its done im thinking changing the lot,
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    Oct 2012
    38
    Well the garage just called who have had it for two days and they have no clue what it so im back to scratch again. They said they can hear it on front passenger side when driving but dont know what it is. Ive only had the car week now so this is really starting to get to me.
    Oct 2012
    38
    Right folks think i have found my problen dedpite the garage having the car for 30 hours. As some of you said the battery slid around so now ive wedgednit witha block of wood.
    Thankyou for your help
    Aug 2012
    Medway, Kent
    162
    No problem, as I said something simple to look at which I know has caused a few issues Glad it's sorted mate.
  1. Funny noise when turning right
    By jamesbeacroft in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th November 2009, 21:25
  2. A6 Steering Clunk When Turning
    By watsonk in forum Handling
    Last Post: 18th March 2006, 08:30
  3. Noise when turning right
    By daverob in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2005, 22:40
  4. creaking / clunking sound (offside front) when turning right ?
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2005, 22:38
  5. Occasional grinding when turning right..
    By Pegsta in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th January 2004, 22:28
