AH FabricationsEM Tuning
    VTEC_Killer's Avatar
    Oct 2006
    West Yorkshire
    78
    Turbo not kicking in - loss of power!
    Car was running ok this morning, then it felt that there was no 'surge' as if the Turbo wasn't kicking in.
    Continued on my journey for 8 miles (mainly flat, so no big issue) but as soon as I got to a hill, the car was in limp mode - no power at all to climb the hill (car really struggling)
    Anyway, I switched the engine off as soon as I got on the flat, started up and then things were like back to normal again - the turbo was working ok!
    I did a quick search on the forum, and the MAF Sensor/N75 seems to be the main cause (though I will try to get it on VAGCOM).
    Q's?
    Where is the MAF and n75 sensors located and can I replace these myself?
    What will be cost?
    How do you best clean the turbo with Mr Muscle?
    Thanks in advance.
    2004 Audi A4 1.9TDi Sport with GMbH Bodykit
    RNS-E, Parking Sensors, Privacy Glass, Xenons
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    The maf and n75 are at the top of the engine ill take a pic for you later. Both easily replaceable mate and not too exspensive
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    Maf around £50 and n75 £40 I think last time I bought one. But that was for a 1.8t s3
    Nov 2011
    South Lanarkshire
    81
    Maf sensor is on the air box. N75 valve is on the front of the engine. Just follow the vacuum hose from the turbo actuator . N75 valve is just under £40 from stealers. Have a search for the mr muscle turbo cleaning post. I've recently done both and it's cured my llimp mode problems.
    M
    Oct 2009
    Hull
    1,442
    forget looking at parts and prices till you have done a scan and you know what you need
    Oct 2006
    West Yorkshire
    78
    Update:
    Drove the car home yesterday, no problems - everything seemed to be ok.
    Got it on VAG, no engine codes detected except for some unsual ones from con unit, so all good there - cleared codes, went for a blast, re-test - all good!
    Drove in this morning, no issues.
    Pretty weird, I think! I guess I'll see how it goes over the next few days/weeks.
  1. Audi A4 1.9 tdi turbo not "kicking in"
    By jones1066 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2012, 23:55
  2. Loss of power..hit turbo-boost KITT...not!
    By todgerino in forum Diesel forum
    Last Post: 23rd July 2010, 18:57
  3. Engine light on and turbo not kicking in
    By magicdaps10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th May 2009, 20:23
  4. Loss of power - blown turbo?
    By polycage in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th July 2004, 01:03
  5. Turbo not kicking in!
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2003, 11:22
