Chris NottJMB Retrofits
Results 1 to 14 of 14
    S23
    S23's Avatar
    May 2012
    Torbay
    139
    Add S23 on Facebook Visit S23's Instagram Channel
    Quattro question
    I'm running staggers wheels on my 1.8t Quattro 8.5f and 9.5r after putting these on the drive feels weird abit shakey , does running different size wheels affect the 4wd system the tyres are 225/40/18
    my other thoughts are tracking should I get this looked at ?
    Just wondering if anyone else has had an issue similar to this
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    from my understanding, and i may be wrong, the quattro system likes all 4 wheels to be the same,
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,538
    As above really. Due to having permanent 4x4 you will have a different rolling radius from front to back as the rear tyre is stretched on a wider rim........in short the rear wheels are trying to turn faster than the front
    You could get a wider tyre with lower profile to get a close rolling radius as the front but then the grip goes to pot also.
    It's good practice to have the same size alloy and tyre all round on a 4x4
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    S23
    S23's Avatar
    May 2012
    Torbay
    139
    Ok thanks guys think in going to for for some bbs lm or just a set of rs4 wheels
    Greeny233's Avatar
    Mar 2011
    Llangollen
    656
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    Quattro question
    I'm running staggered rims on my Quattro 8.5 front and 9.5 rear with 235/35-19s all round and have no problems at all.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I think the theory that you should have all four wheels the same is 100% sound, but .... the difference in rolling radius would be pretty minimal. If your vibration is that bad, then I would look at other issues before rushing out for new wheels.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,509
    If the rolling radius is within 5% i think it is, you are fine. So assuming you have the same tyres fitted front and rear but one set with some stretch, I think it's more likely something else causing your problem. The quattro system has no way to know what width the tyres are but the radius can affect it
    Mar 2004
    148
    I run 8.5" and 9" on mine and there are no issues.
    thats with the same size tyre allround
    Are the tyres you are running new? or part worn as some part worns tyres have tread blocking, ie uneven tyre wear!
    S23
    S23's Avatar
    May 2012
    Torbay
    139
    There brand new Kenda 225/40/18
    Apr 2012
    lincs
    210
    if you're running the same tyres f+r then apart from the 'stretch' they're the same rolling radius.
    225's on a 9.5 are well outside recommendations tho (i know nothing about the stance and stretch biz tho) which suit 255 or 265's. (7.5" / 8" are a 225 fit)
    pink.teg's Avatar
    Jan 2012
    Cardiff
    170
    I have 8" f. And 9" r
    same size tyres and its all good
    235/40/18
    oh do you know if its cool to have 18" x8.5j ET 20
    on an A4 B6
    Quattro Jam B12 suspension kit ,Custom Droplinks F/B , HID 6000, 18" RS4 Alloys, summer AMG's .
    RS6 for Show's .Cat gone for walkees, sports six padded clutch DMF
    Remapped 173BHP///278lbft, RS4 F/R ARB's , happy with that ........
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    225 on a 9.5 rim seems a bit to much to ask IMO... I'd say you need at least need 235's min.... This why is may seem strange
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Greeny233's Avatar
    Mar 2011
    Llangollen
    656
    Quattro question
    I'd start with having the wheels balanced and check the wheels are centred on the hubs correctly (check there are spigot rings if the wheels require them)
    Oct 2012
    426
    Having run all sorts of quattro's over the last 20 years I have never heard of running staggered wheels on them, I have heard that running wheels of different rolling radius's winds the transmission up eventually leading to a gearbox blow up. the only quattro I ever had with a gearbox problem was one that had previously been driven with odd sized on, (mot failure sheet to prove) not long after the box blew.
    I wouldn't use odd sized tyres or staggered rims, Audi don't either!
  1. quattro question
    By mikeya4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th July 2012, 19:45
  2. My new 1.8 tsport quattro questions
    By JPH04 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2009, 13:41
  3. Owners 2.0T FSI Quattro question
    By Steve-L in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2007, 17:42
  4. Quattro question?
    By WilkoS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2006, 16:08
  5. Quattro question
    By Dandle in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2005, 18:00
