AH FabricationsVolks Autos
    Apr 2010
    27
    1.9TDi (PD) - Timing belt Tensioner, Pointer moved
    I changed the timing belt on my B6 Avant on Sunday and got here in the end. The pointer was set in the middle of the "gap", turned the engine by hand more than 2 times and everything locked up nicely, cam and crank.
    Started the car and it started up fine - left it idling for 5 or so mins whilst I plugged VCDS in to check the Torsion Value\Synchro Angle in measuring block 4 and it's now -0.6 instead of 0. Which I'll fix tomorrow. Engine seemed fine, no weird noises.
    However, having tuned the engine off & looking at the tensioner (top timing cover & engine cover haven't been fitted yet) - the pointer on the timing belt tensioner has moved out of the gap to the right and is towards the edge of the back plate - about 4-5mm movement in total. The "hook" is in the block and fully engaged.
    Is this OK or do I need to strip the car down and redo the timing?
    Any comments\help would be appreciated before I start running the car in a day or so.
    Dibs
    Apr 2010
    27
    Checked the tensioner this morning (cold engine) using an endoscope to get a proper view and it was just to the right of the gap, so thought that having come across a few mentions last night on the web that upto 5mm is acceptable and should sort itself out as the belt will stretch\settle in.
    Also checked the lug with the endoscope and it was fully home - so started the engine, which started straight away.
    Been down to Brum and back (250 miles) and no issues of any kind and the car feels spot on.
    I plan to leave it till the weekend and check the Torsion value and see if it has changed from -0.6. Also be interesting to see if the pointer comes back closer to the middle.
    Dibs
    BA4
    Jun 2012
    Ireland
    76
    Yea it's perfectly normal for them to move as if you look at it with engine runnin it does be movin back and forth
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,090
    This reminds me i ment to re-check the Torsion Value\Synchro Angle again on mine after having run it for a couple of months after doing my belt.... what figure are you aiming for ??? i set mine to eactly zero when i did the belt as this seemed to give the smoothest tickover however beforehand it was set to around -0.5 which seemed to maybe give a little better mpg ( Hard to tell ) but that could be down to the old belt stretching .... whats the ideal setting ??
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Oct 2009
    Hull
    1,434
    as close to zero as possible i believe
  1. Timing belt tensioner/ idler pulley
    By Lemon S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2012, 21:02
  2. TIMING BELT TENSIONER DAMPER (06B 109 477)
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2011, 11:55
  3. Failed timing belt tensioner
    By ben4866 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2011, 18:45
  4. timing belt tensioner
    By nightyx25 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th October 2010, 09:59
  5. what Timing Belt,tensioner,water pump..
    By griffin1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2007, 22:23
