    Greeny233's Avatar
    Mar 2011
    Leuchars
    550
    Follow Greeny233 On Twitter
    Headlight warning stopped working
    As the heading says the warning beep to tell you you have left your lights on has stopped working. I replaced the headlight switch only a month ago is it linked to the switch?
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    Oct 2009
    Hull
    1,433
    Re: Headlight warning stopped working
    Is the dash showing the door open if not then it could be broken wires in the door and the car thinks the door is still shut hence no warning beep
    May as well rule out the easy common things first!
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,708
    There's a buzzer inside the dashboard, possibly in the instrument cluster from memory.
    As Stu says depends whether the door open visual is working?
    Greeny233's Avatar
    Mar 2011
    Leuchars
    550
    Hadn't thought of that but just checked and the Open door display is working fine.
    If I can't fix it i will get my auto electrician m8 to wire something in.
    Already left the lights on twice, don't know how much you need something until its gone.
  1. Low washer fluid warning has stopped working.
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th September 2012, 19:23
  2. Headlight Washers - stopped working
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2006, 13:28
  3. Sunvisor mirror light stopped working
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2004, 16:47
  4. Heated Mirrors stopped working - AGAIN!
    Last Post: 1st June 2004, 22:08
  5. Headlights stopped working
    By skipper316 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2003, 16:26
