Volks AutosSky Insurance
    BEELZEDUB's Avatar
    hippy exhaust guru
    Oct 2012
    nr silverstone
    21
    how to check the timing on a 1.9tdi (130)
    as the title suggests, having my car vagcom'ed tomorrow morn, but i think the problem with my car is either diesel pump out of sync if possible or timing is out in some way.
    see my previous topic for symptoms
    most stuff has now been ruled out, but although i've been told the timing has been checked twice i'm just not sure.
    one of my work collegues today mentioned to me that my audi sounds like a tractor.
    mike
    Jul 2007
    London
    3,074
    There's no diesel pump on your engine, each injector is a mini pump on it's own- google Pumpe Duse for images and explanations. You cannot set the timing wrong on the pd lump without valve to piston contact however you can adjust the "syncro angle" on the camshaft. You need registered vag com/VCDS for that. Too far either way and the engine won't start. If your engine sounds coarse then i suggest you remove the rocker cover and inspect the camshaft and lifters for wear due to wrong grade of oil used !
    FOR SALE:
    BEELZEDUB's Avatar
    hippy exhaust guru
    Oct 2012
    nr silverstone
    21
    it's getting vagcom'ed in a bit so fingers crossed they find something. thanks for the info chap.
    Oct 2009
    Hull
    1,433
    Re: how to check the timing on a 1.9tdi (130)
    Check the synchro angle in engine module group 4 it should be as close to zero as possible
  1. How can I check the work that has been done on a4
    By Dids44 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th July 2012, 10:29
  2. How do you check the level of power steering fluid in the resevoir?
    By CHRIS555 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th February 2011, 11:57
  3. HELP how do you tighten the timing belt tensinor
    By hoban81 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2010, 15:40
  4. How to Check/Refill the Battery Electrolyte in a VW Passat
    By volkspares in forum Volkswagen and other VAG
    Last Post: 31st August 2009, 09:23
  5. How to tell the time
    By marms in forum You Tube Links
    Last Post: 22nd June 2007, 00:51
