EM TuningVolks Autos
    AudidriverA4's Avatar
    Sep 2012
    182
    Interior Lights not working when door is opened
    Hi
    I've just noticed that my interior lights have stopped working, when a door is opened, Nothing, but the funny thing is if I flick the switch to the I(manuel on) position they all light up, just not when the door is opened or when the car is turned off :uhm:
    The rear lights also not working
    Now I installed front ambient lighting the other night so maybe that had something to do with it :laugh:
    Is there a fuse that controls the interior lights that could have blown?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    any damp on pass floor
    all locks mirrors etc working ?
    Sep 2012
    182
    No floor is dry as a cork,
    Yep every thing else is working
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    Worn micro switch in locking module......common prob with the VW group and starts off intermittently before completely failing.
    Some bodge a replacement switch but most replace the whole module.....usually the drivers side as that is opened and closed the most.
    Try drowning the lock catch in some wd40 as yours is stuck closed
    On a VW it averages about £100 a side and is a straight swap. Did one in my previous car as the switch for me became stuck open meaning my lights were on all the time
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Apr 2012
    202
    Quote Originally Posted by AudidriverA4 View Post
    Hi
    Have you tried all the doors? Do the door show up on the dash panel as being opened? If it's not working off all the doors I would rule out each door lock being faulty.
    If the lamps work in the manual on position the power to them is ok so is the permanent earth. I would find a wiring diagram and check the wire from the convenience control unit is switching when a door is opened. I am not 100% sure on A4's but it should be a switched earth.
  1. A6 C5 interior lights not working on drivers side
    By JohnG60 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 7th December 2011, 12:26
  2. Interior lights not working
    By Mr Singh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd September 2010, 20:25
  3. Interior lights not working.................
    By sc00byd00byd00 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th May 2010, 14:50
  4. Interior Lights not working!
    By bhavin1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2010, 19:40
  5. Interior lights not working
    By 02audis3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2010, 09:13
