Results 1 to 8 of 8
    gonna getcha
    Dec 2006
    somewhere where the the speed limit is over 150mph.
    72
    Does anyone use lambda spacer on the rear of cat?
    Hi, Does any one use those spacer on the rear sensor of your cat when you play around with the cat? To stop light coming on the dash? Thinking about this on my decat? Cheers
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,536
    i have used them a few times
    sometimes they work sometimes not
    i find the draft designs the best to use.
    gonna getcha
    Dec 2006
    72
    Cheers for the quick reply. Nice one!What is the difference in the draft designs and others? Did it work on your car? Cheers Bud.
    Mar 2008
    1,058
    ive put non foulers to mine 500 miles and no light
    gonna getcha
    Dec 2006
    72
    VR6GORDY, Cheers for the reply, Did you use two a friend in work said to use two? Cant it be coded out the light? My friend said was to trick the ecu. I want to get all the angles of the job in hand before i tempt in to doing it. Cheers Bud....
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,323
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    no ' i just map mine out
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    Mar 2008
    1,058
    Quote Originally Posted by cominatcha View Post
    i did use 2 .. had to cut the threads of one and weld it to the other i do have 2 spair if you wanna buy of me and make your own up
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Not a good idea as the ECU is getting a false reading. It should be mapped out.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
  1. Does anyone use this aftermarket rear bumper lip?
    By H88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th July 2012, 01:53
  2. Replies: 2
    Last Post: 28th November 2009, 15:53
  3. GSM Prep.... Seriously, does anyone use it?!
    By PNH80 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th March 2008, 16:16
  4. max size spacers on the rear??????????
    By 20vtdaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2007, 11:09
  5. does anyone know how to replace the Lambda sensor?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2005, 23:26
