Chris NottMonster Motorsport
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By murran
Thread: Cambelt jumped two teeth !!!!
    Jun 2011
    130
    Any possible damage ?, water pump seized, car was turned off immeadieatly, garage said they can retime hopefully
    audi a4 3.0 quattro
    Jul 2010
    Chelmsford, Essex
    46
    What speed was you doing?
    Probably damaged inlet valves, might be easier to fit a recon head instead of taking it to pieces
    Jun 2011
    130
    Only about 5mph !, i reckon i should be fine, you never know though, at least the insurance comp is paying !
    Jul 2010
    Chelmsford, Essex
    46
    The slower the speed, the less damage. I'd be surprised if it was damage free even at 5mph.
    Definitely worth getting it fully checked over. If any of the valves are bent you'd hear a tapping noise on tickover. But I'd get it towed to be looked at
    Aug 2010
    1,540
    oh dear. best to get a new belt on it, all timed up correctly then do a compression test. if the compressions seem fine then go ahead and build it up and start it.
    if the compressions arn't ok then its pretty pointless building it up as the relavent head will need removing to fit new valves. just put it together to the point where you can safely crank it on the starter.
    also i wouldnt start if its got suspected bent valves. the heads of the bent valves might snap off and cause major piston/head damage!
    VagPro likes this.
    Jun 2011
    130
    Well everything changed and all ok, no damage occured !!!
    bit of a belt type noise from engine bay though, is this normal ?, maybe just the new belt etc
    May 2012
    596
    I pulled off at less than 5mph into a roundabout when my timing belt tensioner bolt snapped....and it bent every thing! Had all valves etc replaced and the head was sent of to be reconditioned..... so im guessing jumping teeth would do similar at that speed. Sorry to blow that on you but if your not paying thats a bonus
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition 220bhp, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights. remap/diverter valve soon
    Gone - 2005 B7 A4 SE TDI Avant 2.0 140bhp
    Jun 2011
    130
    Garage said it was all spot on an running fine, just took it out for a 50 mile run, and i agree !
    guess i was very lucky !!
    Aug 2010
    1,540
    if i were you id go fill out a lottery ticket incase your luck hasnt run out just yet lol...............
    Aug 2010
    1,540
    Quote Originally Posted by boomtown View Post
    belt noise? not unusal for a new belt rollers etc to be slightly noisy as it settles in. it'll either wear off or get worse. if its not disapeered in 100 miles or so then get it checked. better safe than sorry! could be something like a belt cover not fitted right.
    but you might be imagining it as its all been apart for the belt changed.
    i mean before this happened, did you ever really have the bonnet up while its running and taking notice of the noises it made?
  1. Two options ... CRY or JUMP off a Cliff!!!..
    By JonBoi21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2011, 15:25
  2. help!!!advice needed cambelt jumped off 2.5tdi v6 2004 cabriolet
    By davidfox280585 in forum General Automotive Chat
    Last Post: 4th December 2009, 06:54
  3. new tyre needed - do i need two though?
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th September 2003, 13:56
  4. When to change cambelt??
    By Joules in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th April 2003, 14:25
  5. Replies: 5
    Last Post: 1st April 2003, 10:24
