Monster MotorsportEM Tuning
    Lancaster
    1,785
    Heater flap repair - Bit of DIY
    Hello!
    Hopefully this will be a good enough fix.
    My heaters have been stuck in HOT for months. The wife hates my car, when we use it she has to melt in the passenger seat.
    I had to get the glove box off as the hinge had snapped.
    So whilst it was out, I decided to pop off the motors.
    I popped off the screen flap motor first as this sometimes refuses to open.
    The actual pictures are of the centre flap motor iirc. It was just for the sake of pictures.
    Once off the car, carefully open up the case by pushing in the clips and opening it all the way round.
    As above, I have taken it apart.
    Pop out the motor first, gently lever it out from the power connection end.
    Then pop out the long cog.
    Carefully remove the sensor ontop of the round cog.
    Put all the parts somewhere clean and safe.
    To remove the main cog, turn over the case and gently pry the outer connection from the cog. It will just pop off.
    If yours is like mine, you'll find the cog is quite tight in it's holder.
    Put it out and give it all a good clean up.
    Give all the parts a really good clean. I found having a mate to hold a cloth tight whilst you run the cogs over the edge of the cloth helped clean out nooks and crannys.
    Once you've got it all lovely and clean. I opened up the hole in the plastic up a touch with some wet and dry wrapped round a bolt. Keen doing this until the cog turns nicely in the hole.
    Once done, give the unit another good clean up.
    Now you need to grease everything back up. I used a light white grease we use at work on moving pistons.
    Smear any mating faces. Make sure the white cog turns nicely in the unit. I found it was alot freer after this. My heatflap motor was nearly solid!
    Pop the white cog in first, then push the outter connection on. It will only go in one way. I tried to get it back in line as it was before as much as possible. Whether this is needed, I'm not sure.
    Grease up the long cog on the metal part and on the cog bits.
    Put a small smear of grease on the cog of the motor and pop it back in place. Sticker points up.
    Pop the case back on and give it a try.
    I ran heater calibration afterwards but it seemed to work fine before the calibration.
    I also put a smear of grease on the joints of the lever on the heater box.
    Hope this helps!
    To do: None yet.
    Jan 2011
    687
    Nice one. Like you I hate to just buy bits to replace, I like to strip down and see if I can fix it.....
    Scanned my car and its telling me my defrost flap motor was out of range or something (I cant remember the error code right now), so I will have to strip it I am thinking.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Nice one, I need to do this to my defrost flap motor one day! (Although it's been running fine of late...)
    Reminds me of doing the slow wiper repair, the mechanism was so bloody stiff I don't know how the motor moved it at all!
    Lancaster
    1,785
    I thought the same when I did the wiper fix from your how2 James.
    Well, I had to do a 180 mile round trip on Thursday after work to see the wifes Gran. I had cold feet all the way there and back. I did all the ones on the passenger side and left the drivers. Typical!!
    So this morning I popped off the lower dash panel to find that it'd actually snapped the arm onto the motor.
    So I took it off and headed into work to use their stuff.
    I used Loctite 406 with primer to repair the arm and did the same mods to the motor as I had on the other side. Put it back on and it didn't do anything. Ran vagcom on it and now it works perfectly.
    Well chuffed.
    To do: None yet.
  1. Heater Vent Icon illumination - How To DIY!
    By Woorlord in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5 Days Ago, 08:38
  2. Heater flap motors - where to buy
    By jbcalvin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th February 2014, 19:29
  3. Has the heater flap gone? no hot air
    By JA50N in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th April 2012, 21:05
  4. has anyone got a heater flap?
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd September 2010, 17:44
  5. Audi DIY repair site...
    By evilscotsman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th May 2008, 17:47
