EM TuningAH Fabrications
Results 1 to 12 of 12
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    replaceing coolant temp sensor????
    right ive got the old one out and the new one in place without the wire and clip in place yet.
    its in place now but doesnt feel very stable at all ? does it need to be right in or does it clip in place.
    Oct 2009
    Hull
    1,434
    engine?
    clip holds it in place but it should push home and feel sturdy
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    1.8t engine mate i must just need to give it abit more force or is there a certain way it goes in
    Oct 2009
    Hull
    1,434
    Im not sure on the 1.8t as mine is a TDI but on mine you have to give it a good old shove then attach the clip
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    think ive sussed it derrrr!!! clip pusshes in around the housing and not the sensor itself, thing is ive gone a bust the clip now Grrrrrrr!!
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    Temp sensor replaced but still coming up with the fault code??? Thermostat stuck open next option?? Maybe water pump ???
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,722
    What fault code is it giving you?
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    17698 buddy
    pauldazzle's Avatar
    Cardiff
    558
    Did you put a genuine VAG CTS in?
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    pauldazzle's Avatar
    Cardiff
    558
    17698 is the lower temp sensor (G83) look here Lower coolant sensor with fault code help... 17698 P1290
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    That will be my problem then I've replaced the top one. Are the sensors both different or the same???
    Yeah proper vag cts
    Cheers mate
    pauldazzle's Avatar
    Cardiff
    558
    Different, the lower sensor is a 2 pin.
  1. coolant temp sensor replacement
    By scott13 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2011, 15:33
  2. Coolant temp Sensor
    By imported_Tariq in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2006, 12:38
  3. URGENT - COOLANT TEMP SENSOR
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 22:13
  4. V6 coolant temp sensor & idle speed control valve
    By JDA in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2004, 18:27
  5. Coolant Temp Sensor
    By teknobod in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd January 2004, 11:14
