    May 2012
    Cheshunt , Herts
    22
    Where is the Oil Pressure Switch on a 2.5Tdi ???
    Hi all, i would be grateful if someone could tell me where the oil pressure switch is located n the engine bay as i need to replace mine, hopefully the car will stop bleeping at me then !!!!! Many thanks in advance, Nick
    Jul 2007
    London
    3,252
    Next to the turbo on the distribution block from where the turbo takes it's oil feed ! You cannot miss it ! There's 2: one is the low oil pressure sensor, the other is the oil temp. sensor and there's also an oil level/quality sensor fitted on the bottom of the sump !
    FOR SALE:
    May 2012
    Cheshunt , Herts
    22
    Many thanks for that, i shall have a good look on monday as i hope it is simple to fit, thanks again, Nick
  1. oil pressure switch where is it
    By harvey01 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2012, 19:46
  2. 2.0T - Where did the oil go????
    By Fast3000 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th May 2009, 21:36
  3. Where is the oil temp sensor?!
    By calvin in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2008, 09:01
  4. Oil pressure switch on A8 2.8 V6
    By mikeem in forum A8/S8 forum
    Last Post: 11th October 2008, 14:23
  5. Torque setting wanted for the oil pressure switch
    By kninio in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th June 2007, 22:36
