Hi all, i would be grateful if someone could tell me where the oil pressure switch is located n the engine bay as i need to replace mine, hopefully the car will stop bleeping at me then !!!!! Many thanks in advance, Nick
Next to the turbo on the distribution block from where the turbo takes it's oil feed ! You cannot miss it ! There's 2: one is the low oil pressure sensor, the other is the oil temp. sensor and there's also an oil level/quality sensor fitted on the bottom of the sump !
