Volks AutosBadger5
    Apr 2012
    11
    A4 2.5 TDI Cabriolet No brakes and No turbo
    I have recently had my a4 cabriolets cam belt replaced, however, it appears that in the process, I have lost brakes servo assistance and turbo boost. Perhaps something has happened to the vacuum pump in the process. Do the vacuum pumps on the 2.5tdi fail completely? Is there a way of telling whether it is the pump at fault?
    Jul 2007
    London
    3,255
    Check the plastic hose that comes off the brake vacuum pump at the back of the passenger cyl. head under the coolant bottle. The hose goes to a 1 way check valve which has a nipple which is prone to break. If it's broken then you can put some 2 parts resin bonding glue and let it set. You can buy 2nd hand on ebay , see this for example: PASSAT AUDI A4 A6 2.5 TDI - VACUUM PUMP CONNECTION PIPE | eBay
    or this: PASSAT AUDI A4 A6 2.5 TDI - VACUUM PUMP CONNECTION PIPE | eBay
    FOR SALE:
    Aug 2010
    1,540
    ah, take the pump off the back of the n/s head. i bet whoevers changed the cambelt has lost or broken the drive bit. as you need to remove it to fit the cam alignment tool when doing the belt!
    or as adam said theyve snapped the plastic hose.
    take it back to the garage and kick off as theyve caused this!
    Apr 2012
    11
    I would not let the same garage touch it with a flag pole, been a bad experience overall. Shall check out the pipe and if not remove the pump. Will update on how I get on. Thanks for the advice.
  1. ECS Brembo/porsche brakes and 18" RS6 replica's
    By Tin in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2004, 10:59
  2. Brakes and standard wheels?
    By icecavern in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2004, 08:14
  3. brakes and clutch upgrade
    By youngdriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th April 2004, 19:17
  4. 2003 tdi sport, new rack and fuel gage prob
    By A3Lee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th October 2003, 21:28
  5. Front brakes and Discs
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2003, 14:08
