I'm pretty sure I know the spacers that I'm after (H&R Trak+), but just not 100% certain on how much I should go on each side and the really awkward thing is that the wheels are in storage right now and I'm not certain on the specs of my original alloys (the 16" "Trapeze" alloys that were standard on Sport spec A4's until they went to 17" as standard).
I have a weird feeling that they're something like 6.5J and ET54? Can somebody please confirm this?
I'm pretty sure that my Winter tyres are 215/55/16's.
Given that the 18" Avus III's (ET45) are 8J and wear 235/40/18 rubber, then an extra 15mm on each side should be reasonably comfortable without ANY risk of fouling, shouldn't it? 20mm wider tyre, so that's 10mm each side and ET45 vs ET54, so that's 9mm further "out" already.... so 15mm each side will be closer to the stance of the Avus III's....
Not sure if any of these would help...
The only photo's I have with the correct tyres on are distance shots:
Closer up, but please note that these are with 205/55/16 rubber, so definitely won't look quite right!
Or should I be aiming for more than 15mm each side? If so, I think I might get the tyres back from storage (and get them fitted to the car) and then order the spacers once I've done some measurements...
